Go to Post When you find yourself saying multiple times at one regional "...never coding at 1am in the hotel again... ...never again..." - BigJ [more]
Unread 07-03-2016, 11:45
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
ADXRS453 gyro returning incorrect rate above medium speed
Last year was our first year using the ADXRS453 and it was beautiful but this year it is giving us issues. When we turn clockwise faster than +100 º/s it jumps to a negative rate and when we turn -200 º/s it gives a rate around 0. The max rate for this gyro is +/- 300 º/s. We've tried multiple gyros and we have the same problem and are using the same code from last year to read it (code here http://bit.ly/1U2Xplj). Has anyone experienced anything similar with the ADXRS453 or other gyros?
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 07-03-2016, 12:21
Re: ADXRS453 gyro returning incorrect rate above medium speed
I've never seen this behavior before with either the 450 or 453. Have you tried feeding your assemble_sensor_data function some pre-fabricated data and looked at how it responds?
FYI, WPILib now has a class to talk to the 450/453 out of the box. It looks nice. You might want to try that.
You are also ignoring errors reported by the gyro in your code. I'd suggest handling them (at least don't integrate the new value for that cycle.) I've heard of that causing problems.
Unread 07-03-2016, 12:39
MaxMax161's Avatar
Allegedly Useful
AKA: Max Llewellyn
Thanks for the quick reply! I'll try your suggestions.
