Go to Post WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Katie_UPS [more]
Unread 07-03-2016, 12:10
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant future
kangaroo barrel connector size
We damaged our barrel connector pretty bad for the Kangaroo. I can't find the size anywhere online and microsoft has been totally worthless trying to figure it out.
Is anyone able to tell me the size of the barrel connector? Outer diameter, inner diameter, length?
Thanks!
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 09-03-2016, 18:39
ImMoMo's Avatar
ImMoMo ImMoMo is online now
AKA: Mo
FRC #2559 (Normality Zero)
ImMoMo is an unknown quantity at this point
Re: kangaroo barrel connector size
Hey!
I've tried searching around, however, I can not seem to find anything either..
I would suggest that you try some different connectors that you have lying around, in my experience lots of electronics use the same type of DC - in barrel connector.
Try one of the connectors that come with the routers each year, maybe you'll get lucky?
I'll look around some more, good luck!
Unread 09-03-2016, 18:42
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Originally Posted by ImMoMo View Post
Hey!
Just make sure you get the polarity correct. Most things are center pin positive, but better to take the time to check (if your current, damaged plug can still output voltage, putting a multimeter in there only costs a few seconds) than to fry the board.
Also, I really don't like the idea of "getting lucky" when trying random electronic components, and hoping for the best.
Unless they are my own personal items that I don't care about.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 09-03-2016, 18:53
ImMoMo's Avatar
AKA: Mo
I agree it's not the best solution. If you are going to do this I too would suggest a multimeter to check the polarity.
Also make sure you confirm the proper DC voltage required before you connect.
Unread 10-03-2016, 01:15
ahartnet's Avatar
Was able to get a best guess and found that a 1.1 mm ID and 3 mm OD works!
