Go to Post Someone tried throwing out a perfectly good fleece blanket! It even had the quadratic formula on it! WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Karibou [more]
Unread 09-03-2016, 15:07
Allthatslack Allthatslack is offline
None #1389
Allthatslack is an unknown quantity at this point
Longer battery wires
Hello,
So I was wondering if people have lengthened the wires from the main breaker and the PDB (or PDP as it called now) to the battery?
Unread 09-03-2016, 15:13
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Re: Longer battery wires
Andymark sells long (36") battery cables so I think it's possible but can't say for sure. As for connecting the ends of the wires, no idea.
Unread 09-03-2016, 15:22
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
You're only allowed 12 inches on the battery half of the Anderson connector <R5>. You could, theoretically, use a longer cable on the other side and still comply with <R36>, but I would urge you not to do so. Every bit of current your robot uses goes through that cable, and more length is more resistance is more wasted power.
Unread 09-03-2016, 15:24
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
You can make the wires as long as you want. Just know that an increase in length increases the resistance in the wire run. Too long, and your robot may have brownout issues. Make the wires as short as you possibly can.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 21-03-2016, 10:23
natejo99's Avatar
natejo99 natejo99 is offline
Captain/Human Player
AKA: Nate Johansen
FRC #0074 (Team C.H.A.O.S.)
natejo99 is on a distinguished road
We lengthened our wires by soldering and heat-shrinking extensions onto the PDP side, in order to allow our breaker to be more accessible. I wouldn't recommend more than about 2 feet of wire total between the two, just in case you run into issues with too much resistance.
2013-Present - Student, FRC 74
2014 FRC Champions - 254, 469, 2848, 74
2014 FRC MSC Finalists - 1718, 67, 74
2016 Traverse City District Winners - 3688, 74, 6128
2016 Tesla Quarterfinalists - 74, 2054, 4468, 3238
Thanks to our 2016 Alliance Partners:
4580, 71, 2405, 3572, 3688, 6128, 5505, 2054, 4468, 3238
Unread 21-03-2016, 13:18
philso philso is offline
FRC #2587
I would not recommend soldering 6AWG. The wire acts as a heatsink and you might not get the solder to "connect" to all the strands, giving you a high resistance joint. It would be better to use a proper crimp lug and crimper to make joints in wire this size.
The resistance of an extra few feet of 6AWG should not cause brownouts. The table linked below shows Maximum Resistances in the range of 0.38 to 0.50 Ohms per 1000 feet. Passing an 100 A current through 1 foot of 6 AWG should only cause 50 mV of voltage drop.
A more likely cause for brownouts are bad joints in the power wiring. These could be bad crimps or loose screws or nuts on the lugs/terminals. I found several teams with loose battery cable screws over the last week. One had their radio drop out both matches they used the battery with the loose terminal screw.
Unread 21-03-2016, 13:45
To put things into perspective:
6 CIMs pulling 40 amps each (it happens) is 240 amps. One foot of 6 AWG drops about .1V at 260 amps. That .1 voltage drop causes about 1.7% loss of max mechanical power.
Unread 21-03-2016, 13:54
FRC #2587
Yes it does. Most teams would probably have a hard time noticing 1.7% power loss, especially if it is a transient condition.
One of the other posters had stated that a few feet of extra 6 AWG could lead to brownouts (which most teams would notice).
Unread 21-03-2016, 15:49
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Absolutely. I had helped a team in San Diego that had about a 6 FT run of 6 AWG going from their main breaker to the PDP. Shortening the run solved their issue.
Battery voltage can be affected by three factors, temperature, state of charge and current. The one we're really talking about here is current. A lead acid battery has internal resistance. As you move current through the battery, the voltage changes due to its internal resistance.
Lets simplify it a little bit.
When you're charging a battery with some low current, you'll see the battery voltage increase. Charging it with a larger current, you'll really see it increase.
Same thing applies to the discharge. Discharge it with a small current, you'll see it decrease; discharge it with a large current, you'll see the battery voltage really decrease.
Now apply this same theory to having long interconnects with your battery. Say you're drawing current at some C rating that's near the limits of the battery, your voltage will likely be pretty low. Combine that with the voltage drop due to large current draw over a long run of cable.
This situation is extremely prone to causing brownout conditions.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 21-03-2016, 22:13
FRC #2587
I suspect the problem with the robot you helped fix was really some bad crimp or the nut on the breaker not being tight, leading to a high resistance connection (this is assuming that the battery did not get changed in the process). The drop caused by the wire resistance, even at 240 A through 6 feet of 6 AWG would be 0.72 V if we use the maximum rated wire resistance. A bad connection can easily give you more voltage drop, up to 12 V.
I am not advocating that we should have excessively long power wiring but we should solve the real problems.
Unread 22-03-2016, 12:52
kiettyyyy's Avatar
Fortunately, that wasn't the issue. Their crimps were done well, screws and nuts were tightened down sufficiently on both the breaker, battery and PDP.
Edit: Al beat me to it.
-Kiet Chau
www.team1538.com
Unread 22-03-2016, 13:50
FRC #2587
I'll take your word that the crimps were good and the screws and nuts are tight. What sort of motors did they have in their drivetrain? How much wire was removed from the loop in total?
My gut feeling is that if cutting out a few feet of wire made that much difference (you probably didn't cut out 12 feet or even 6 feet if they started with 6 feet), they are probably still just above the brownout threshold of 6.8 V. It is likely that they still have some other issues such as batteries with high internal resistance and that it is likely that their brownout problems will return.
Unread 21-03-2016, 22:39
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
According to Ether, 6 AWG wire loses .1 V at 260 A PER FOOT. Running an extra 6 feet would lose .6 V, or a 10.2% loss of mechanical power. This is something many teams would notice.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 21-03-2016, 22:41
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Question - why?
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 22-03-2016, 07:28
OK,
running worse case calaculations, a four motor CIM drive will draw ~480 amps at stall. 480 amps will drop .48 volts for every 2 feet of #6, please include the red and black wire in your calculations. The 6 foot run would be 12 feet of wire added to the two feet on the battery and about another equivalent 2 feet for properly crimped connectors and terminals. That adds up to almost 4 volts dropped in just the wiring feeding the PDP whenever you start driving or reverse direction. Add that to the internal resistance of the battery and you potentially have only 3 volts available even on a fully charged battery.
Jumping back to my easy calculator the WIRE FOOT, every WF will drop 0.1 volt at 100 amps.
Battery Internal Resistance=11WF
1 ft. of #6=0.5WF
1 ft. of #10=1WF
1 ft. of #12=2WF
When you view your voltage logs, those short dips to the 4 volt level you see are real. Make your #6 run as short as possible. Often you can significantly shorten the run by simply turning the PDP 180 degrees.
