Go to Post There are certain questions that one never, ever should ask. - dlavery [more]
Unread 13-03-2016, 20:14
Catherine57 Catherine57 is offline
FRC #2077
Catherine57 is an unknown quantity at this point
G43 enforcement level
From what you've seen, how tight are the refs calling G43? We're planning to shoot with our bumper in the outerworks, but my general impression was that defenders were not shy about playing defense in that area and I have not seen a lot of penalties called, though to be fair I didn't always have the best angle of view. Do you expect the enforcement to get tighter/looser in later weeks? Is this a strategy that looks good on paper but is too hard to implement in actual gameplay?
Unread 13-03-2016, 20:19
New Lightning's Avatar
New Lightning New Lightning is offline
Master of Tactics
AKA: Scott Hasek
FRC #1987
New Lightning has a spectacular aura aboutNew Lightning has a spectacular aura about
Re: G43 enforcement level
I think that it all depends on the referee crew. In the St. Louis regional finals 2451 was shooting from the outer workds and several times there were bumped while trying to shoot, and the refs calling the penalty seemed hit and miss. Now I was at field level to see whether or not they were actually in the outer works so I'm not sure.
But the refs have a tough job and if they miss a few then it can be understood. Definitely not ideal that they miss calls, but it does and will happen no matter how badly we want it to be the other way around.
Last edited by New Lightning : 13-03-2016 at 22:39. Reason: wrong location for shooting
Unread 13-03-2016, 21:33
Donut Donut is online now
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Originally Posted by New Lightning View Post
I think that it all depends on the referee crew. In the St. Louis regional finals 2451 was shooting from the batter and several times there were bumped while trying to shoot, and the refs calling the penalty seemed hit and miss.
Shooting from the Batter is not a protected area, G43 only applies to the Outer Works (multiple teams were confused about this at AZ North this week).
G43: ROBOTS on the same half of the FIELD as their ALLIANCE TOWER may not interfere with opponent ROBOTS attempting to traverse OUTER WORKS (regardless of direction). A ROBOT is considered traversing the opponent’s OUTER WORKS if any part of its BUMPERS are within the opponent’s OUTER WORKS and no part of it is in their opponent’s SECRET PASSAGE.
We watched for this whenever defense was being played in the Courtyard this weekend. Remember that G43 requires Bumpers be within the Outer Works for a foul to be called for interference. If the Bumpers were not clearly within the side Shields of the Outer Works then it was a no call. After seeing where many teams stopped to take their shots this weekend I would advise that you make it as obvious as possible you are within the Outer Works; on some of the shots the team probably thought they were protected by G43 when their Bumpers were actually too far forward. The drive team is looking from across the field (even if using a camera on a pole) so your viewing angle may make your position appear different than the sideline referee's view.
I think G43 is more likely to be missed in the Neutral Zone. With Outer Works to be watched on both sides and robots flying across the defenses at high speeds contact there can easily be missed if it's not for an extended time.
Unread 13-03-2016, 21:54
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
I didn't get a chance to watch every single match at GTRE, but for the few that I watched, G43 was enforced pretty well. It was quickly and accurately assessed every time it happened IMO.
2013 FRC World Champions (1477, 1241, 610)
Queens University Computing Class of 2020
2013-2016: Team 610
2017-????: Team 4476
Unread 13-03-2016, 22:01
FRC #2077
That sounds pretty good. It is nearly impossible to tell what the penalties are from video and I didn't do much better trying to watch the live matches. We'll see how it goes for us after we get the shooter going.
Unread 13-03-2016, 22:39
Master of Tactics
AKA: Scott Hasek
FRC #1987
I meant to say outer works in my post. They were shooting from the outer works not the batter.
Unread 13-03-2016, 22:47
cad321 cad321 is online now
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
I too tried to keep an eye on the G43 calls at GTRE while I was there saturday and agree that the refs appeared to be pretty on the ball when it came to making those calls.
Unread 13-03-2016, 23:00
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Refs called it at Lakeview. We got too close and made contact in the playoffs with a team shooting in the outerworks and got hit with a penalty. Only made the mistake once.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2016: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 14-03-2016, 00:12
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
The penalty did not seem to be enforced well at Arkansas. Although we really only had a few outer works shooters (3937, 3507 and 5437 come to mind, although 5437 generally shot from a few feet in front of the OW) it seemed like they got beaten up on with little or no repercussions to the aggressor.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 14-03-2016, 03:30
backdrive backdrive is offline
FRC #0649
backdrive is an unknown quantity at this point
At CVR the refs almost never called fouls, although this might be because teams often crossed defenses, went into the courtyard a bit, then came back on to a defense to shoot. I'm a bit confused on whether or not hitting an opposing bot that does this constitutes a penalty or not.
Unread 14-03-2016, 05:20
Anteprefix's Avatar
Anteprefix Anteprefix is offline
FRC #1678 (Citrus Circuits)
Anteprefix is on a distinguished road
It looked like refs were only calling the G43 when it was really obvious that there was contact. Often, the refs wouldn't call it if the shooting robot only had bumpers over the ramp, but would call it if they were actually touching the ramp.
The scouting! It never ends!
Unread 14-03-2016, 06:33
Tomker's Avatar
Tomker Tomker is offline
AKA: Tom Kertesz
FRC #1690 (Orbit)
Tomker will become famous soon enough
In Israel it was called most of the time but not enough as far as I'm concerned. The thing is, if they don't give a foul each and every time it is being done, it becomes a viable strategy to keep ramming into the shooter - you are only punished with a foul once in a while and manage to keep your opponent from weakening their tower (since they have less opportunities to make shots).
I think they should have either instructed the refs to call it ALOT more often, or change the ruling so that each of those fouls would also weaken the tower's strength by 1.
Unread 14-03-2016, 11:23
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
This is a foul
Q532
Q."A robot carrying a boulder crosses a defense into their opponents' courtyard. They then move back such that a part of its bumpers are within the opponent’s outer works while their robot is still in contact with the courtyard carpet. They attempt to line up a shot, but an opponent contacts them. Does the opponent incur a G43 penalty?"
A.This situation does demonstrate a violation of G43. Per G43: "A ROBOT is considered traversing the opponent’s OUTER WORKS if any part of its BUMPERS are within the opponent’s OUTER WORKS." Even if you are shooting a BOULDER, you would be protected by G43 if your BUMPERS are within the OUTER WORKS.
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
Unread 14-03-2016, 16:57
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
We found that rule was enforced quite well. We made a distinct effort to get into the OW to make it clear to the ref. I rarely saw other teams actually shooting from the OW--they were often off the OW which makes a hit legal.
Unread 14-03-2016, 13:09
Data Nerd
FRC #0079
Out of curiosity (mostly because I saw it happen a few times to us) how would a team shooting, getting hit, and plowed (i.e. other bot remains in contact) into the outer works likely be called?
-S
