Go to Post If you think that teams would never bypass the rules or do something unsafe (intentional or unintentional), I suggest you spend a weekend as an inspector. Every bad scenario that you can think of, we have seen. - Al Skierkiewicz [more]
Unread 14-03-2016, 09:48
TJolley TJolley is offline
FRC #4020
TJolley is an unknown quantity at this point
Question About Robot Cart Rules
According to the admin manual section 4.2.3 "All carts should fit through a standard 30-inch door;" the carts must fit through a standard 30-inch door, however our robot is wider than 30-inches and the cart that was built to move the bot is 32 inches wide. Should we rebuild the cart to be 30 inches or just leave it as is.
Thanks
Thomas J
Operations Dirictor
Team 4020 Cyber Tribe
TJolley@DBCyberTribe.com
www.DBCyberTribe.com
Unread 14-03-2016, 09:57
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Question About Robot Cart Rules
It really depends on your venue. The 30" limitation is made because in many places you may need to fit your robot can cart through an actual standard 30" door. As far as I know, no one goes around measuring robot carts, so I doubt you'll have someone coming by telling you your cart is illegal.
And as for a >30" wide robot... if you run into a narrow doorway situation, you can always turn your robot 90 degrees on the cart (assuming its a rectangular robot). I believe FIRST chose the frame perimeter the way they did to ensure that most robots would fit through standard 30" doors getting in/out of venues. Obviously, add bumpers or a non-rectangular frame and you might have an issue... but I think they were hoping that most venues wouldn't have that issue between the pits and the field, and that non-rectangular robot teams would plan ahead knowing it would be an issue.
2016: Lake Superior WFFA
Unread 14-03-2016, 10:39
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Thanks
Thomas J
Operations Dirictor
Assuming you are going to the Smoky Mountains Regional, you won't have a problem with that venue.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
