Lights to help aim
I have seen several teams using a light to help them aim when taking a shot. Could anyone recommend a light to use and any tips to using a light.
Re: Lights to help aim
Most people are using LED rings from here: https://www.superbrightleds.com/
I have seen them advertised as both "halo" and "accent" lights. |
we use a Maglite® ML100™ LED Flashlight Black
Is the maglite a focused beam of light because we are looking for a light that is focused so we can hit shot from the back of courtyard.
Take a look for yourself:
https://www.youtube.com/watch?v=nhmnSkCYeLk |
Although we're not using the system this year, we used an LED alignment system in 2014. Feel free to PM me or Billbo911 if you want to learn about how we set it up.
#7
My team uses Labview and could use some assistance in setting up the use of LED lights to help aim. Our idea was to be able to determine when our robot was at the right distance from the castle wall to shoot. We have the LED mounted on our camera but are not able to set it up in Labview. IF you can help walk us through this, email me at ahudson@adairschools.org and I will forward it to our programmer and he can communicate with you better than I can.
#8
Are you using the two-cell or three-cell version? Did you have to use a voltage regulator to drop the voltage to 3 V or 4.5 V?
#10
973 was very effective with a focused flashlight for aiming. They just lined up made the light reflect off the chains and boom in. Wish we thought of that rather than wasting time on auto-aim with LED
#11
Fair warning, our team used a flashlight to aim our shot with incredible success throughout all of our qualifications matches, however, in Eliminations, our opponents said that our flashlight was distracting/blinding them during the match. We were forced to unplug the flashlight, significantly dropping our accuracy. Be careful about relying on a flashlight to aim, I highly recommend you have some sort of fallback solution.
#12
Controlling your light via a relay should avoid this complaint. I've seen several teams (oursleves included) that turn their light on as part of their firing sequence. We tend to already be turned towards the tower by then, so we don't shine in anyone's eyes.
#13
Does anyone referee the validity of the claims of distraction from opposing teams? You definitely don't want to legitimately distract people with bright lights, but at the same time, I could see saying "hey, that's distracting! make them disable it!" as a way to gain strategic advantage.
#14
Did you leave your light on all the time or turn it on only when the shooter was on? Is your flashlight very large/bright? We used China's finest Cree LED $6 specials from amazon.com. Cheap, light, bright, effective. And not overpoweringly so. I remember seeing the light sweep through the opposing driver stations at Pittsburgh on the way to aiming, but the hardy Ohio and Western PA types must have less sensitive eyes than those in New York City, cuz no complaints were lodged. I remember 25's ridiculously large and bright lightzooka from 2012 being on all the time. I was standing behind the driver's glass watching matches at CMP and I remember the thing practically blinding me. I'm fairly sure it could induce migraines in people. I don't believe anyone asked for that to be turned off. If you are pointing the light at the opposing drivers for an extended period in an attempt to intentionally distract them, that's one thing. If you are merely using the light for its intended purpose of aiming and shooting, that should be TOTALLY acceptable by ANY head referee. Running the light off a relay will certainly help matters. If this becomes a thing, you can rest assured I will wage war against all those annoyingly bright green LED rings that are on 24/7/365 during a match. Those are CLEARLY meant to distract and annoy, right? They don't serve any other useful purpose in a match, do they? [/sarcasm] #teamflashlight #allyourvisionledbelongtous Last edited by Travis Hoffman : 14-03-2016 at 16:53. |
