Go to Post Maybe you should whack it a few times with a hammer. That always seems to fix our robots. - Adam Y. [more]
Unread 22-03-2016, 05:41
Ruse Robotics Ruse Robotics is offline
Ruse Robotics is an unknown quantity at this point
3 x 5" wheels?
Hi so
The Tetrix All Terrain Tire has official dimensions of 5", but the tread seems to add almost another inch in Inventor. I've tried to put three wheels together on one side. With the current spacing to avoid part interference, and to stay within the size limit of 18", There's less than 2mm between the outermost of these wheels. I've heard that these wheels do squish and deform, which means they might actually touch each other when pressed down with the weight of the bot. I haven't actually seen a bot use three of these wheels on one side before, but if anyone has, or has tried it, is there actually a problem or is this just a misrepresentation?
Thanks
Unread 22-03-2016, 10:26
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Re: 3 x 5" wheels?
I'm not sure why you would want to use the Tetrix All-terrain tires, other than the part that they may look a little cool to you. I highly recommend against using these. Every team I have seen use these has problems, and never makes it past state/regional. Each tire is about 2 inch wide as well..
Is there a reason you need to have 3, 5" wheels on one side? Side by side, or in a row?
I highly recommend wheels from Andymark.com, as some are cheaper, while all of them provide better traction on the FTC Mats. (i.e Stealth Wheels, Plaction, or Performance)
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 22-03-2016, 10:57
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: 3 x 5" wheels?
Sounds something like an FTC version of a 6 Wheel Drivetrain
Academic Student (Forever)
Unread 22-03-2016, 11:29
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Re: 3 x 5" wheels?
I highly recommend against using these. If you REALLY want six wheels for (I'm assuming) driving up the mountain, try some 4" plaction wheels (if the 5" is really important you could machine your own)
It isn't shiny enough.
Unread 23-03-2016, 17:58
Re: 3 x 5" wheels?
Yeah pretty much the intention
Thanks for the advice, as I said before, we really haven't ever had much to do with the Tetrix ATT so we don't know terribly much about its performance.
Apart from the ones already mentioned (AM plaction/performance), are there any other wheels recommended? Thanks for the responses
Unread 23-03-2016, 18:27
Re: 3 x 5" wheels?
You're welcome! Only other thing I can think of is VEXpro VersaWheels. They're the closest thing you can get to the banned white AM wheels regarding traction.
http://www.vexrobotics.com/vexpro/mo...rsawheels.html
Unread 23-03-2016, 19:25
josesantos's Avatar
josesantos josesantos is online now
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
Re: 3 x 5" wheels?
If you're dead set on 5" diameter wheels,VEX EDR has some. Interfacing with Tetrix will require some creativity.
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
Unread 24-03-2016, 10:46
Re: 3 x 5" wheels?
Whelp decided to knock out a modified 5" version of the am-2031 in Inventor, now with directly compatible Tetrix holes
Not sure if machining/milling it would be feasible later though
Appreciate the suggestions
