Workshop/Tools/Parts
Hi, my team has $5000 to spend on parts, tools, and machinery for next season so what should we purchase? I know we won't know exactly what we need for next season until then but we need to spend this money by tomorrow. We are trying to purchase machinery for our new workshop but are unsure as to what would be the most useful. Are there items that will be necessary that we do not receive in the KoP next season (e.g. roboRIO)? We're interested in purchasing a new laptop so feel free to recommend one as well. Thank you!
Re: Workshop/Tools/Parts
It would help to know what you already have.
A lathe, CNC router, etc can all be helpful. |
QFT. We can't help you unless we know exactly what you need help with.
Though I suppose I would start with the basics of drill press, table saw, band saw, bench grinder / belt sander. OP mentioned as well buying a second (assumedly second) RoboRio, and that would be a good investment as long as you intend on utilizing it for either a full fledged practice robot or testing bed. I would focus on sustainability first; buy all of the parts that you know that you'll need and utilize first, then get tools that can help you advance to the next level of building. |
Small tools gathered being, at minimum:
Wrench set Screw driver set Battery operated drill and assorted drill bits Hack Saw Allen set Next I would acquire tools that are more specific to FRC that your average garage wouldn't have; mostly electrical tools and supplies would fall under here: Various spools of 12/16/18 gauge wire (In both Red and Black/Blue) A decent crimper (Preferably a ratcheting one) Soldering set Assorted insulated connectors Assorted motor controllers (REV Sparks are cheap, though seems like Talons are the Tier 1 controllers) Afterwards, I might start looking into getting some stock building materials that you know you will be using, whether that be plywood, sheet metal, box tubing, 80/20, assorted fasteners, etc. From here, I would start grabbing some of the more advanced tools that I listed, such as: Band Saw Drill Press Belt Sander / Bench Grinder Welding set/station Compressed Air station Laser engraver 3D Printer *Note - you could go a bit more on the "expert" end of the spectrum and replace the Drill Press with a Machining Mill. On the very far side of the spectrum, if you're really comfortable (and have the space), utilize what Mr. Gregory suggest and buy things like: CNC Router Lathe Plasma Cutter (If you extensively utilize metal) Addition reading on the subject. Last edited by CalTran : 22-03-2016 at 18:25. |
Look at the end of this document, it's a bit out dated but it has a pretty complete tool list.
http://www.chiefdelphi.com/media/papers/3138 |
#7
Before buying equipment decide what you training resources are. If you buy tools like a lathe and have no person to use or teach operating the lathe it is not a good investment at this time. Look into used or donated used machine tools. You also must plan for the space you will have. In our machine shop the tools take up 1/3 of the shop space, work benches take about 1/6, and clear space takes up 1/2. The clear space was increased from 1/3 and much of the robot assembly and testing is done there.
#8
Thank you so much! The input and resources are greatly appreciated and helpful!
#9
Definitely bandsaw, drill press, socket wrench, and 2 hand drills + batteries for starter. Then 2 fractional drill bit sets (you really need both). Allen wrenches (AKA hex wrenches), at least 2 imperial and 1 metric set, preferably 3 and 2 instead.
A few fine or general-purpose metal files for deburring. Maybe a set of needle files for getting into hex bores. A deburring tool with the little hook-chaped blade is great for circular deburring, as well as countersinks (82*, not 90*). A medium size bench vise and low-profile mini vise are helpful. You definitely need a rolling toolbox. One with ball bearing drawers will last an age compared to regular ones. Tackle-box-like boxes are fantastic for organizing screws and small parts. Start organizing immediately or you will regret it. A shelving unit, also rolling if you don't have a permanent space for it, will come in handy later. So will a few 2015-style totes for storing large items or projects as long as you make sure to keep them uncluttered. Magnetic tool/parts dishes also help with cluttering. If you want to use #25 chain, the Dark Soul chain tool is great to avoid paying for masterlinks. The first major tool I would buy would be a mill, but the associated accessories like collets, drill bits, endmills, and vises can run a pretty penny, at least $1000 to get set up well imo. But a mill with DRO is one of the most useful tools a team can have imo after they have the basics. Stock up on things like aluminum stock tubing, preferably versatubes for the ease-of-use, and hex shaft. EDIT: Holy cow Spectrum's list is amazingly perfect, definitely take a look at that above. Last edited by asid61 : 23-03-2016 at 00:36. |
#10
For small parts storage, these http://www.harborfreight.com/tool-st...ase-93928.html, http://www.harborfreight.com/8-bin-p...ase-93927.html are very nice for the price. When closed they do a very good job of not getting parts mixed up between bins and you can take one of the bins with you when you need a bunch of 1/4 20 bolts, or whatever. Also look online for ideas for making rolling cabinets to hold a bunch of the cases. Adam Savage has a Tested video about the storage cabinets he made for his Sortimo cases. Of course being Harbor Freight items make sure you look for coupons before you buy anything. |
#12
I'll also add that, as much as we all want a dream shop, what you need to do robotics is nowhere near what you want. We just got through our first build season, and we worked in an area where we had to set up and tear down at every meeting. We did have a 26" rolling toolbox and a copious amount of shelving for bins of parts and equipment, but our only real shop tools were an 8" drill press and a 10" compound miter saw. We also had a few cordless drills, a jigsaw, an angle grinder, a Dremel, a compressor and a rivet gun, and a variety of hand tools.
#13
We buy from OnlineMetals. Consider buying: 1"x1" angle 2"x2" angle 1"x2" tube 1"x1" tube Depending on the game sometimes you need stronger the .125" thick and sometimes you need light weight .060" thick. We buy a mixture. |
#14
We go to Alan Steel locally, and a few others go to Coast Aluminum. |
#15
As for the RSL and breaker switch, you will get another in next year's KOP, but if you want more than 2, you can probably ask some teams near you that have been around for a few years, as they would most likely be willing to let you have one or two (they pile up quickly). |
