Go to Post Heat Gun(n.):Your build season replacement for a microwave. - jajabinx124 [more]
Unread 23-03-2016, 14:43
axiomofdarkness's Avatar
axiomofdarkness axiomofdarkness is offline
FRC #1403 (Cougar Robotics)
axiomofdarkness has a spectacular aura aboutaxiomofdarkness has a spectacular aura aboutaxiomofdarkness has a spectacular aura about
Manually cancelling a Command
Hello,
I am trying to create a Command subclass which listens for an interrupt to cancel the command. When cancelling the command, I have tried using the Cancel() method, but it fails when the command is part of a CommandGroup. Is there a universal way to forcibly end a command from within the command itself?
EDIT: Also, can the Cancel() method be used on a CommandGroup object? If so, I could work around this issue.
Unread 23-03-2016, 14:56
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Manually cancelling a Command
Within your command:
if(getGroup() != null) getGroup().cancel();
else cancel();
Unread 23-03-2016, 15:27
else cancel();
Will this cause issues if multiple commands are trying to end their parent CommandGroup?
Unread 23-03-2016, 14:57
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Originally Posted by axiomofdarkness View Post
Hello,
What about listening for the interrupt and setting a variable that will finish the command during the next iteration?
Unread 23-03-2016, 15:29
Hmm. What does it mean to "listen" for an interrupt?
Unread 23-03-2016, 15:48
I have a background thread that checks for a certain button combination on the joystick being pressed. The Cancel() method will be called when that condition is true.
Last edited by axiomofdarkness : 23-03-2016 at 15:50. Reason: Made wording clearer
Unread 23-03-2016, 15:53
That's polling, not an interrupt.
Unread 23-03-2016, 16:38
My mistake - I apologize for the error. What would an interrupt be then?
Unread 23-03-2016, 17:05
The hardware generates an electrical signal (called an interrupt) that causes the CPU to stop what it's doing, save its "context", jump to a new location in program memory, and start executing there. That location is called an ISR -- interrupt service routine. When the ISR is done executing, it tells the CPU to go back to where it was when the interrupt occurred. The CPU uses the saved "context" to go back to where it was, as it was.
You can see there is no polling involved. That's the advantage of interrupts.
The disadvantage is that interrupts can occur at any time -- asynchronously -- so you have to be careful when using them.
