Go to Post OK guys, the robot's overweight. You know the drill. - DonRotolo [more]
Unread 24-03-2016, 08:50
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
How much air would this use?
I know I could probably look into myself but I was wondering with other people's experiences, how much air would a pnumetic cylinder like this one use? I am trying to think of ways to make our robot better and I was wondering how many tanks we would need to extend and retract this roughly 6 to 8 times. We don't have a compressor on our robot, or any other pneumatic systems. This would be used for our kicker for the ball, instead of a motor with a paddle, we would add this to force it directly forward into the wheels, if that makes sense.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 24-03-2016, 09:17
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: How much air would this use?
Pressure1 * Volume1 = Pressure2 * Volume2 (with some atmosphere accounting as well)
Pressure 1 = Storage Pressure (at tanks)
Volume 1 = Total Volume of all tanks
Pressure 2 = Working Pressure (at cylinder)
Volume 2 = Volume of extend + Volume of retract for entirety of match (note - they aren't quite the same)
We used this simple equation to figure out how many tanks we would need to extend/retract our intake (3" stroke, 1.25" bore, up to 6 times in a match), kick/hold cylinders (1" stroke, 0.75" bore, up to 8 times in a match) and shifting cylinders (0.5" stroke, 0.75" bore, up to 4 times in a match). Once we had an exact amount of tanks (2 for us) we added one tank as a buffer between our calculations and what our calculations didn't account for.
If we keep the pneumatics topped off at 110 PSI (literally have the kids tether/enable in queue the match before), we haven't had a problem maintaining > 60 PSI.
GitHub
Unread 24-03-2016, 09:29
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
For future questions, I would suggest this excel calculator created by Paul Copioli: http://www.chiefdelphi.com/media/papers/3166
It has an air usage calculator but also a calculator for center-to-center hole spacing for chain, and a in depth calculator combining multiple different motors within one gearbox.
Paul's Calculator and JVN's Design Calc are two things always open for me during build season for solving design problems like yours.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 24-03-2016, 09:49
JesseK's Avatar
FRC #1885 (ILITE)
Wow! This thing is way easier than what we came up with and is very close to our final results. Thanks for a re-link!
GitHub
Unread 24-03-2016, 11:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Now I'm itching to modify Paul's calculator to cover multiple working pressure pneumatic systems. Or possibly toss in compressor calculations, but that'd get complicated quickly....
Unread 24-03-2016, 11:53
Levi Madden's Avatar
Levi Madden Levi Madden is offline
Student
FRC #1987
Levi Madden is on a distinguished road
The best way to figure that out is to test it. It's not too difficult to make a basic pneumatic set up with it, all you need to do is plumb in a solenoid to the cylinder, and then try different amounts of tanks, you should be fine with 2-3 tanks.
Unread 24-03-2016, 11:55
bkahl's Avatar
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
Originally Posted by Levi Madden View Post
you should be fine with...
This saying is a bit of a pet peeve for me.
Why not do the math first, then test exactly what the math says? It could save you from throwing unnecessary tanks at a pneumatic system, something too many teams do.
Team 125
Team 195
Alumni
Facebook
EWCP
Unread 24-03-2016, 12:05
Student
FRC #1987
I know, It was a recommended starting place. Do the math and the testing then decide how many you need, keep in mind that you don't want to run until you have empty tanks, you want to run until your stored reaches below your working. Usually when someone says "I think" or "it will be fine" it's never just "fine".
Unread 24-03-2016, 12:08
bkahl's Avatar
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
In my experience there's no such thing as too many tanks
Weighing in at about .64lbs a piece* (Black Clippard Tanks), there is absolutely a point where you can reach too many tanks...
*http://www.andymark.com/product-p/am-2649.htm
Team 125
Team 195
Alumni
Facebook
EWCP
Unread 24-03-2016, 12:11
Student
FRC #1987
Agreed, there is such thing, account for what you need and then add a little more.
Unread 24-03-2016, 12:13
Knufire Knufire is online now
In 2014, Warlords (2485) found that a 5gal sheet metal tank was a more efficient solution weight and volume wise compared to the necessary amount of black Clippard tanks given the air usage of their pneumatic catapult.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 24-03-2016, 12:15
Student
FRC #1987
We wanted something like that last year, but we thought all of the large tanks like that we found would never pass inspection.
Unread 24-03-2016, 12:17
Why not? What rules were you concerned about?
