Go to Post He told me "I guess I am still learning Mr. King." I told him "That's a good thing. So am I." - mathking [more]
Unread 24-03-2016, 14:26
nlt5 nlt5 is offline
FRC #5676
nlt5 is an unknown quantity at this point
Compressor
We are running our compressor off the robot but I read that the robot will still need to control the compressor through the use of the robot code. Will I need to write specific code to call for the compressor to turn on? Can anyone provide me with an example of what the code would look like to call the compressor. We are using iterative based code.
Thank you
Unread 24-03-2016, 15:03
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Compressor
Compressor compressor = new Compressor(CAN_ID_OF_YOUR_PCM);
compressor.setClosedLoopControl(true);
