Go to Post Robotics for me though really is hard to beat. Though tiring and exhausting, the memories you build are priceless. - ShadowKnight [more]
Unread 25-03-2016, 20:51
Jeringo Jeringo is offline
FRC #4749
Jeringo is an unknown quantity at this point
getNumberArray(String) is deprecated
I am trying to get an array value from network tables in java but can't seem to get it right.
currently using this...
double[] width = Table.getNumberArray("width");
but I am getting this
The method getNumberArray(String) from the type NetworkTable is deprecated
how would I fix this?
Unread 25-03-2016, 22:17
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: getNumberArray(String) is deprecated
Deprecated methods means that they are old or may no longer be supported/may be removed in a future update.
However, they should still work. I assume you aren't getting an error, but rather a warning.
As for fixing it: You'd have to use the new way of doing what you are trying to do. I don't know what it is called off the top of my head.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 25-03-2016, 22:59
soundfx's Avatar
soundfx soundfx is offline
AKA: Aaron J
FRC #3238 (Cyborg Ferrets)
soundfx is an unknown quantity at this point
This new method allows you to set a default value as a second parameter to return if no value can be found. The new method is getNumberArray(String key, Double[] defaultValue).
Unread 25-03-2016, 23:42
FRC #4749
after using
double[] defaultval = new double[0];
getNumberArray("width", defaultval );
it says defaultval is a double but it needs to be a double[]
forgive me if im missing something very obvious switched over to java 4 days ago and arrays are not my strong suit
Unread 25-03-2016, 23:44
AKA: Matt B
FRC #1771 (1771)
Originally Posted by Jeringo View Post
after using
getNumberArray("width", double[] 0.0)
i get a misplaced constructs on double[]
Try this:
Double[] x = {0.0};
getNumberArray("width", x);
1771- Mentor (2015)
Unread 26-03-2016, 00:06
FRC #4749
Try this:
Double[] x = {0.0};
this worked thank you
