Go to Post PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. - dlavery [more]
Unread 29-03-2016, 14:27
ROULT ROULT is offline
AKA: pepemanboy
FRC #4403 (ROULT)
ROULT is an unknown quantity at this point
Antenna design
We have seen many robots having antennas like team SCREAM:
and 3005 RoboChargers:
Can you elaborate on the materials and design used?
Also if your team has a different antenna design, or have further ideas, can you share them with the FRC community?
CHEESECAKING
Thanks and good luck to all teams in regionals!!!
Unread 29-03-2016, 14:34
RaMoore's Avatar
RaMoore RaMoore is offline
AKA: Rachel Moore
FRC #3005 (RoboChargers)
RaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud of
Re: Antenna design
On FRC3005, we used black 1/8" polycarb for our antennae. There is also different colored tape on the front and back of each one so the driver can tell the orientation of the robot.
You can vary the width of the antenna to change how "floppy" they are while driving around and still making sure they are compliant enough to bend down under the low bar. Be sure to pack a few extras, we lose 1-2 per competition.
Rachel Moore
REV Robotics | www.revrobotics.com
Unread 29-03-2016, 18:11
AKA: pepemanboy
FRC #4403 (ROULT)
Re: Antenna design
Thanks!! We will take this in account... We really like the idea of having antennas...
See you at champs...
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: Antenna design
They're generally some sort of flexible material supplemented by a springy base. You could try something like these if you're pressed for weight.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 29-03-2016, 15:11
I_AM_Clayton's Avatar
I_AM_Clayton I_AM_Clayton is offline
Jr./Build Captain
AKA: Clayton Miller
FRC #3397 (Robolions)
Team Role: Driver
I_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond repute
Re: Antenna design
Team 945 (Team banana) used something similar, they were flimsy enough to swing around but held on to the robot well.
2014 Gateway Robotics Challenge Winners with 1985 and 2481
FRC IS LIFE
Robolions 3397 pages
facebook- https://www.facebook.com/robolions3397
youtube- https://www.youtube.com/user/robolions3397
Instagram- @robolions_3397, https://instagram.com/robolions_3397/
Unread 29-03-2016, 15:40
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: Antenna design
Team 423 also used "antennas", but we accidentally made them too heavy by adding signage at the top. This caused them to constantly sag and get in the way of everything. Also, they generally cannot go up to max height because when they fold down they cannot stick out more than 15" past the bumpers. We ended up taking them off and making static PVC poles at the height limit for matches where we think there may be a vision issue. It means we lose low goal capability, but we gain vision behind tall defenses, which is much more important in our opinion.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 29-03-2016, 15:51
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Antenna design
We used painted 3/16" fiberglass rod epoxied into a stiff spring with a machined aluminum coupler. The bottom of the spring was attached to the robot frame I can try to find a photo of the mount if there's interest;
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 29-03-2016, 17:07
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Antenna design
We're using something like these fiberglass reflector rods cut down a bit. They go into some aluminum clamps at the bottom that are all pivoted on the same screw. The outside poles have surgical tubing to keep everything centered.
I think it's important to go with something pivoted front/back or that can't bend sideways like those lexan strips, other wise you risk them bending sideways out of the 15". Also having 2 colors front/back or side to side so the driver will know the orientation of the robot.
Unread 29-03-2016, 17:39
FarmerJohn FarmerJohn is offline
Pre-Rookie team
AKA: John Reynolds
no team (Turlock Titans)
Team Role: Team Spirit / Cheering
Rookie Year: 2016
FarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond repute
Re: Antenna design
What are these for?
Unread 29-03-2016, 18:12
AKA: pepemanboy
FRC #4403 (ROULT)
Re: Antenna design
Originally Posted by FarmerJohn View Post
What are these for?
They are basically to aid the driver in locating the robot position and direction because of the visual blocking by defenses and other robots.
Unread 29-03-2016, 18:14
AKA: pepemanboy
FRC #4403 (ROULT)
Re: Antenna design
Thanks to all!! Basically it all narrows to rods with springs and polycarb sheets... Thanks!!!
Unread 29-03-2016, 18:18
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
Re: Antenna design
I saw a team that used old halves of pool noodles - they bent when going under the low bar, and then popped straight back up. they were bright green too, easy to see
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 29-03-2016, 20:12
lorykzarr's Avatar
lorykzarr lorykzarr is online now
AKA: Theo Camilleri
FRC #0854 (Iron Bears)
lorykzarr is an unknown quantity at this point
Re: Antenna design
You could try getting a pack of really long zipties. That or try finding something like those flexible thin plastic driveway/road markers.
Unread 29-03-2016, 20:20
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Antenna design
I suggested we get a bunch of fans and hook it up to a speed controller and get a inflatable tube man. Unfortunately my idea was shot down
https://youtu.be/cvaRGiMWRaE
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-03-2016, 20:43
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
Re: Antenna design
We used Orange Fiberglas arrows ($3.00 each at Dick's Sporting Goods) with two different color fletchings. We cut the points off and epoxied to door stop springs ($1.50 for two at Lowe's). They work great!!
