TalonSRX encoder confusion java
I am getting a little confused on encoders for the TalonSRX.
i am trying to do three things, first thing is the software limit. How exactly does it work. we have a shooter that tilts the upmost position it -1000 and all the way to the floor is 3500 i've tried swapping the values but it only lets me tilt the shooter down. the second thing is how to i reset the encoder or set it to 0? and the third thing is how to i tell the motor to go to a certain position? Code:
Tilt.setFeedbackDevice(FeedbackDevice.AnalogEncoder); Tilt.setForwardSoftLimit(-1000.00); Tilt.enableForwardSoftLimit(true); Tilt.setReverseSoftLimit(3501.00); Tilt.enableReverseSoftLimit(true); int pulseWidthPos = Tilt.getPulseWidthPosition(); int pulseWidthUs = Tilt.getPulseWidthRiseToFallUs(); int PeriodUs = Tilt.getPulseWidthRiseToRiseUs(); int pulseWidthVel = Tilt.getPulseWidthVelocity(); FeedbackDeviceStatus sensorStatus = Tilt.isSensorPresent(FeedbackDevice.CtreMagEncoder_Absolute); boolean sensorPluggedIn = (FeedbackDeviceStatus.FeedbackStatusPresent == sensorStatus); |
Re: TalonSRX encoder confusion java
I don't know the answer to the questions about the limits as I have not used them yet. However, I can help with getting the Talon to a certain position.
Here is an example of initialization of a Talon: Code:
armR = new CANTalon(1); armR.setFeedbackDevice(FeedbackDevice.QuadEncoder); //Set the feedback device that is hooked up to the talon armR.setPID(0.2, 0.001, 100, 0.00, 360, 12, 0); //Set the PID constants (p, i, d), you will need to do some tweaking to get these right Code:
armR.changeControlMode(TalonControlMode.Position); //Change control mode of talon, default is PercentVbus (-1.0 to 1.0) armR.set(height); //height is the value you are looking to move to armR.reverseSensor(true); armR.enableControl(); //Enable PID control on the talon In terms of setting it to 0, here is the code we use: Code:
talonName.setPosition(0); |
You can make a variable to hold your arm distance setPoint, and add/subtract from this value using the joystick's output value. Notice that joysticks have a range of -1 to 1, so you might have to multiply some constant > 1 to your joystick output so that your joystick can have a fast effect on the setpoint. This will all the depend on the distancePerPulse you currently have.
Jerigo,
Have you tried looking at the Talon SRX Software Reference Manual? See the manufacturer's website. |
https://www.ctr-electronics.com/Talo...e%20Manual.pdf |
