Go to Post ...okay, maybe I have a xkcd addiction - plnyyanks [more]
Unread 06-04-2016, 15:51
Bradley Boxer's Avatar
Bradley Boxer Bradley Boxer is offline
AKA: Bradley Boxer
FRC #0303 (TEST Team 303)
Rookie Year: 2015
Bradley Boxer is an unknown quantity at this point
Do dormant VIs use memory on the RoboRIO?
My team has several VIs that are present in the project window (tree) but that are either disabled or not used in the running code. Do these VIs take up memory when the code runs on the RoboRIO? Does anyone have experience/suggestions one way or the other with this?
Thanks for your input,
Bradley Boxer
Team 303 Programming
Unread 07-04-2016, 02:47
Re: Do dormant VIs use memory on the RoboRIO?
The VIs loaded into PC memory are all that are linked into the Robot Main hierarchy. So disabled VIs will load into memory on the PC/host editor. VIs in the project, but not called from Robot Main hierarchy will not.
The VIs compiled and sent to the roboRIO do not include disabled VIs or project VIs that aren't in the hierarchy.
Greg McKaskle
Unread 07-04-2016, 08:47
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Greg's note "VIs that aren't in the hierarchy" means the same as your question "not used in the running code"
So these VI do not get sent to the roboRIO and do not use memory on the roboRIO
Omar
