Slotted Angle Aluminum
Is Sloted Angle Aluminum allowed in the OCCRA competitions?
Slotted Alum Angle
This all depends. If your team takes reg. angle available from listed sources and slots it using appropriate legal tools then there is no problem at all. Hack saws and files along with a drill press works great.
If you are asking about purchasing slotted alum or extrusion alum that is in any special configuration then the question is, "Is this alum available from the approved sources". Please read the OCCRA manual and materials section regarding this situation. If this is not the answer you wanted please re ask the question and I will confer with the other leaders for a clearer answer. |
| PBASIC ARCTAN function | Greg Ross | Programming | 14 | 11-05-2003 12:28 |
| Bosch Aluminum Structural Framing | Carl Owenby | Technical Discussion | 37 | 15-01-2003 21:11 |
| Is an angle bracket allowed? | archiver | 2001 | 0 | 24-06-2002 00:58 |
| Difference in aluminum | archiver | 2001 | 1 | 23-06-2002 23:49 |
| Let's get some aluminum extrusions | archiver | 1999 | 3 | 23-06-2002 23:12 |
