Go to Post Suggesting change is one thing, implementing it is another. - JaneYoung [more]
Unread 19-04-2016, 09:44
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Best multi-tool for robot/field use
I've been carrying my Leatherman Super Tool on my belt at competitions. At REI on Sunday I got to thinking that there might be something more adapted to robotics and field use*. Not that there's anything wrong with the Super Tool -- it's in great shape after 20 years.
I'm giving serious consideration to the Crunch.
The Gerber Cable Dawg and Groundbreaker seem too specialized. Other Gerber tools don't seem differentiated enough from the Super Tool to make it worth switching.
Other ideas?
* REI and Costco have this effect on me.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present ˇ FRC 3081 Kennedy RoboEagles mentor
2013 - present ˇ event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve ˇ www.linkedin.com/in/speterson
Unread 19-04-2016, 10:29
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
Re: Best multi-tool for robot/field use
I've been carrying a Leatherman Skeletool CX for the last eight years, and haven't even considered anything else. The only time I use a multitool over the correct tool for the job is when something needs to be done NOW, and the Skeletool is the only one that is fast enough to the hand to work well for me. Only having the tools I need, and being super light weight for daily carry makes it perfect IMHO.
Unread 19-04-2016, 10:35
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
At SVR I brought both my Leatherman Crunch and Wingman. I found myself carrying the Crunch over the Wingman 100% of the time. The Crunch is a fantastic tool, the locking pliers are simply great. In addition to the pliers, the Crunch also has a nice set of other tools. I would definitely go for the Crunch over any other tool for FRC use. That being said, the Super Tool is still a very nice multi tool, so don't feel compelled to replace it if you don't want to.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 19-04-2016, 10:42
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
I personally use a wave as a daily driver through everything I do. The locking pliers of the crunch look very nice for FRC use though.
Unread 19-04-2016, 10:41
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
I carry my Leatherman Micra in my pocket because it's small and will do minor stuff. I gave up the full size Leatherman it was always in the way and I'd snag stuff when it was in the belt holster.
For events I wear one of those runners belts / waist / fanny packs. I have a different use case since I need special tools.
Mine has in it:
3/32 & 5/64 hex wrenches
11/32 nut wrench and nut driver
Needle nose pliers
Auto - Manual control switch
Wire ties
Small set of nuts and bolts
Bearing block
Axle collars
Band-aids
-- They are small and light and I've found that having the right tool is better than tool that's not quite right. You could match yours up to your robot (torx drives, fuses, etc.) and have the right stuff. Plus I can take it off so it's not snagging seatbelts and other stuff. YMMV
I also have what roboteers call my "Mary Poppins Bag", it's along the same line as items listed above, except there are 2 of each item, a full sized pair of scissors and one of those small hacksaw blade things. It's good for working with a team so more than one person can do things at a time.)
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 19-04-2016, 10:50
Tim Sharp Tim Sharp is offline
Tim Sharp
FRC #3959 (Morgan County Mech Tech)
Tim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to behold
Hmmmm...
http://www.outdoorlife.com/node/1005002800
Unread 19-04-2016, 12:08
Bentorino's Avatar
Bentorino Bentorino is offline
Bentorino
FRC #1983 (Stinkwerkz)
Team Role: Operator
Bentorino is an unknown quantity at this point
I use a Gerber Flik because I find pliers to be the most useful tool to have easily accessible. It has a good pair of scissors and a solid knife, hasn't broken on me in two years of pretty hard use, and is always fun to open
Unread 19-04-2016, 12:30
Bob Steele's Avatar
On the RIBMEATS bandwagon....
AKA: Bob Steele
I have carried about everything by leatherman and also swiss army multitools.
Presently I carry a Crunch and an Squirt ES4 (labeled "bomb defusor"). I also have in my pocket a small set of allen keys and a double end wrench in 3/8 and 7/16.
The Squirt has mini wire strippers and is perfect for emergency electrical work.
Unread 19-04-2016, 13:02
Collin Stiers's Avatar
Collin Stiers Collin Stiers is offline
FRC #1719 (Umbrella Corporation)
Team Role: Driver
Collin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really nice
I recommend the Leatherman wave, but more generally any Leatherman that accepts the Leatherman bit type, Then you can buy the bit set, and have any type of bit you will generally ever need for robotics in you pocket or on your belt, most people on my robotics team have this knife and we all love it, it has most any tool you will ever need, from screw drivers to wire cutter/strippers, and pliers. Great tool, never had any problems with it
Unread 19-04-2016, 13:26
aphelps231's Avatar
aphelps231 aphelps231 is offline
Andrew Phelps
FRC #1318 (Issaquah Robotics Society)
aphelps231 has a spectacular aura aboutaphelps231 has a spectacular aura about
I feel like I've seen this tread before
I have carried a Leatherman Juice Cs4 for the past four years, and it's my baby. I've thought about replacing it but it's been through so much that I would have a hard time doing so. It's small, fits perfectly in the lighter pocket of my pants, and always gets the job done. I find myself mostly using the pliers/cutters and the knife most often, but the scissors come in handy for small stuff and there are also some screw driver bits that I tend to avoid using if possible.
I also carry a 5/32" allen key and a 7/16" driver bit, as those are the most common sized allens/bolt heads on our robot, as well as a dual tipped sharpie and a pen and pencil. And you won't catch me without my clipboard for notes (my short term memory is terrible) and a pit map.
team1318.org
2016: Flight Director, Alliance/Match Strategy
2015: Mechanical Lead
2013-2014: Fabrication
2016: 2x district finalists, Quality, DCMP Entrepreneurship Awards
2015: 3x district winners, Innovation in Control, Creativity, Team Spirit awards
2014: Galileo Division finalists, PNW District Championship winners, 1x district winners, District Chairman's, Innovation in Control, Entrpreneurship awards
2013: Entrepreneurship award
Unread 19-04-2016, 13:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I used to carry a Paladin PT-540 until they stopped selling it and I foolishly snapped the pliers in half trying to twist something with them. It's a modified SOG multi-tool, so it's customizable. Mine was customized with a leatherman bit holder, V-cutter, and extra wire strippers. I think the most useful thing on it was a 7/16 and 3/8 nut-driver on the outside of the handles. Man I wish I hadn't broken it. Or that paladin hadn't stopped selling it.
Currently I'm packing a leatherman Surge, but the Crunch does look awfully tempting.
Unread 19-04-2016, 13:49
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I've generally used a Leatherman Wave without much thought about it. With the exception of electrical work, it generally has anything I need. I do wish the scissors were a bit stronger, but otherwise no complaints.
For electrical work, that Cable Dawg looks tempting. In particular for some of my non-FRC applications.
Unread 19-04-2016, 14:05
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
+1 for the leatherman wave. I pretty much have it on me whenever im in the shop and commonly find it works better than the tools we keep in our toolboxes.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 19-04-2016, 14:30
DinerKid's Avatar
DinerKid DinerKid is offline
AKA: Zac
FRC #1768 (Nashoba Robotics)
DinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of light
I carry a Leatherman Charge TTi with the bit kit. Just having pliers and a knife is incredibly helpful. The tool is a reasonable size and weight to carry everyday. The addition of the bit kit makes it usable for a quick bolt check if there aren't proper hex keys around. It is nice that the newer leatherman models have tools early accessible without opening the whole thing up.
~DK
Unread 21-04-2016, 03:14
TheModMaster8's Avatar
TheModMaster8 TheModMaster8 is offline
Active Alumni
FRC #5492 (Robo Jockeys)
TheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the roughTheModMaster8 is a jewel in the rough
I've always got my trust ball peen and rubber mallet, best on only tools you need
2009-2011: (FLL) Robot Builder / Operator
2012: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2013: (FRC Team 2783) Fabrication / HumanPlayer / FLL Ref
2014: (FRC Team 2783) Fabrication Student Lead / HumanPlayer / FLL Ref
2015: (FRC Team 2783) Fab Student, Teacher / HumanPlayer / Backup Driver / FLL Ref / FLL Mentor of 6 Teams
2016: (FRC Team 5492) Fabrication Student Lead / Driver / FLL Mentor of Crestwood Elementary
Past Alliance:(2783, 1208, 4154)(2783, 1002, 4265)(2783, 1182, 3868)(2783, 451, 4028)(2783, 1208!, 1288)(5492, 63, 1014) I Will Never Forget
