Go to Post So as you're thinking about this, think simple. - Cyberguy34000 [more]
Unread 22-04-2016, 10:50
Allthatslack Allthatslack is offline
None #1389
Allthatslack is an unknown quantity at this point
Last minute Question on Lights
One quick question;
Is it possible to turn on and off a light using the Signal and Ground ports on the roborio? Or is there another way to wire up a light that allows one to manually turn on and off the light?
Thank you,
Team 1389 The Body Electric
Unread 22-04-2016, 10:54
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Last minute Question on Lights
A simple MANUAL switch works.
If you want the RoboRio to do it, then the conventional way is to use a Spike Relay.
Signal line works if the LED does not exceed the power draw limit of the signal line.
Unread 22-04-2016, 10:56
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Our team hooked all of our LEDs to the PCM since we have no pneumatics
Unread 22-04-2016, 11:00
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
PCM is an option, but if you are using pneumatics you'll need to be careful with how much current you draw( this depends on how powerful your LEDs are)
Facebook
Unread 22-04-2016, 11:03
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Do you have any current draw issues with doing this?
Unread 23-04-2016, 16:51
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
No. We have four strips that run the length of our robot (~30in) and we've never had any current issues (I think we load tested them at around 200mA last I remember... that number may be totally wrong though)
Unread 22-04-2016, 10:58
pilleya's Avatar
Elec+Mech
Yes, we are using a spike to control the high power light ring on our robot and it works great. You'll need to be able to run you LEDs on 12v to be able to use it
Facebook
Unread 22-04-2016, 10:59
None #1389
Thank you all! I will tell my team and we will see what works best for our robot. I will let everyone know what come up with!
Unread 22-04-2016, 12:50
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
Hi 1389! Team 4242 used a zoomable led flashlight, a voltage converter, and a spike relay to do this on our robot. We're sharing a bus with you guys on the way to St. Louis and I'd be happy to tell you everything you need to know. Until then, check out this thread:
http://www.chiefdelphi.com/forums/sh...22#post1558122
