Go to Post ...okay, maybe I have a xkcd addiction - plnyyanks [more]
Unread 23-04-2016, 21:40
Dpurry23's Avatar
Dpurry23 Dpurry23 is offline
Programmer/Control System/Scout
AKA: Darian Purry
FRC #0207 (Metalcrafters)
Dpurry23 is an unknown quantity at this point
Exclamation Using PID in autonomous to keep straight
Need help figuring out how to use PID to go over an obstacle turn to a certain point. (ex. The position that the robot calibrates at)
This is the code I have so far.
myRobot.SetSafetyEnabled(false);
myRobot.Drive(-.5,0.0);
Wait(1.5);
myRobot.Drive(0.0, 0.0);
turnController->SetSetpoint(0.0f);
Wait(2.0); // Have to wait till the bot turns
Language is C++
Unread 24-04-2016, 01:18
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to behold
Re: Using PID in autonomous to keep straight
Wait(1.5);
Language is C++
You can't use a PID loop without a feedback source, e.g. a gyro or encoders. Do you have a gyro or encoders on your drive?
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
Unread 24-04-2016, 01:44
Dpurry23's Avatar
AKA: Darian Purry
Sorry for not explaining, we are using a gyro as a source with the output being our drivetrain.
Unread 24-04-2016, 01:54
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Ok thanks. At its simplest, you could do something like this:
double angle = robot.getAngle();
double angleError = AngleYouWantToBe - angle;
double output = constant * angleError;
myRobot.drive(output, 0);
Wait(2.0);
myRobot.drive(0, 0);
This is a simple P loop. It takes the angle error, multiplies it by a constant you specify, and applies that as the output for your drive. As you get closer, your output gets smaller because the error gets smaller, and it coasts to a stop. Note that due to the fact that a drive train needs a certain percentage to actually drive (e.g. 10%), it will never actually make it the whole way to where you want it to go with just a P loop, although you could make it where it gets pretty close, depending on how you tune your constant.
If you want to get more complex than that, you could use a PI loop, but that's another story.
My FRC History:
Unread 24-04-2016, 06:53
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Here is the problem:
PID presumes continuous measurements. If you are crossing the low bar with no jerky movements, then PID works ok for driving straight (our robot drives like a slightly drunken sailor).
Over the other Defenses, the jerkiness throws off PID. You will eventually head in the right direction (gyro), but you may be off track to the left/right.
Unread 24-04-2016, 16:24
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
You'd only be off by a few inches. That shouldn't be a problem.
We used proportional control to drive straight in auto, and we didn't have any problems.
Unread 24-04-2016, 18:06
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
SamcFuchs will become famous soon enoughSamcFuchs will become famous soon enough
Yeah but the issue is its unpredictability. For example, the ramparts tend to send robots in any direction, and there's no good way to predict that. Also, a couple inches can be a big deal, particularly when trying to shoot without a vision system. Earlier in the season, we calculated that the margin of error when shooting the high goal in auto (if you go straight through the low bar and spin) to be ~1.5 degrees and 2-3 inches IIRC.
Sam Fuchs
236 TechnoTicks, Old Lyme, CT
2015 - Programming, Electrical
2016 - Lead Programmer, Co-Driver
2017 - Lead Programmer, Co-Driver
Unread 24-04-2016, 19:02
xjschwen xjschwen is offline
FRC #3668
xjschwen is an unknown quantity at this point
We did not use a PID just the Proportional part of it... and it is good enough to cross the ramparts in auto, then spin 180 and cross them again during lab work. We never had any issues staying straight on any of the defenses.
There are some items that we will be cleaning up in the off season but it did work.
As a matter of fact auto was better then telle-op.
https://github.com/WhitmoreLakeTroBo.../CMDdrive.java
https://github.com/WhitmoreLakeTroBo...tCaluator.java
Unread 24-04-2016, 21:26
Dpurry23's Avatar
AKA: Darian Purry
Here is a link to our entire code https://github.com/Dpurry23/FRC-Team.../src/Robot.cpp
