Go to Post In conclusion we will have a spaghetti game - Darkseer54 [more]
Unread 03-05-2016, 20:13
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
pic: Swerrrve
Unread 03-05-2016, 20:14
kyle_hamblett's Avatar
kyle_hamblett kyle_hamblett is offline
Hamby
FRC #1073 (The Force Team)
kyle_hamblett will become famous soon enoughkyle_hamblett will become famous soon enough
Re: pic: Swerrrve
That's a good chunk of power behind each wheel. I have never seen a swerve with a CIM + miniCIM combination. Also, bumpers give it the 2451-esque feel
Unread 03-05-2016, 20:23
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: Swerrrve
Definitely looks better with the CIM + MiniCIM setup on each corner, and I like how you've kept up the small form factor on the first stage reduction gearboxes!
I think your bumper supports could be a bit more aggressive, but maybe that's just me.
Unread 04-05-2016, 11:10
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
Re: pic: Swerrrve
grabcad link?
Unread 04-05-2016, 11:58
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud ofKevin Ainsworth has much to be proud of
Re: pic: Swerrrve
Nice job!
I like how you integrated everything into the frame members.
That should reduce the overall weight.
I would also like to see the CAD for it and get into the finer details.
Unread 04-05-2016, 19:48
Team Role: CAD
Rookie Year: 2015
Re: pic: Swerrrve
Now all it needs is an underglow
Thanks! Yeah, the way the bumpers are supported is a little weird.. I'm trying to explore different ways of doing stuff
Originally Posted by Roboshant View Post
grabcad link?
Just uploaded: https://grabcad.com/library/2nd-swer...-in-progress-1
Originally Posted by Kevin Ainsworth View Post
Nice job!
Thanks!
Here it is: https://grabcad.com/library/2nd-swer...-in-progress-1
Unread 04-05-2016, 19:54
Team Role: CAD
Rookie Year: 2015
Re: pic: Swerrrve
Oh and don't mind the lightening holes. Thats just how I waste time when I get bored
Unread 04-05-2016, 20:09
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: Swerrrve
Now that I've seen the CAD:
1. Why chains over belt for the first stage? That's going to be running at a rather high speed.
2. You might have trouble with the round spacers on the bottom of the casterboxes, because you are using screws on both sides. Why not either use a screw + nut or hex standoffs so you can get a wrench on it?
3. Why live axles over dead axle on the last stage, and why 3/8" bearings instead of just thunderhex bearings? It saves some machining imo.
4. Are you sure that the casterbox won't hit the VP output shaft when it turns? I can't tell from the model.
Apart from that it looks good.
