Jaci's Annual FRC Datadump 2016
Welcome to the inaugural release of my FRC datadumps
![]() You can download the sql database here. It contains data about every match, stat, event, team, rank, district, award... everything. The database itself is about 13MB but it's been zipped together with some instructions and examples to bring the filesize down to about 5MB. So let's see what we can do with it.... How about seeing all the matches your team has had over 100 points? ![]() Code:
SELECT matches.key, events.short_name, match_scores.total_points, match_scores.alliance_color FROM matches INNER JOIN events ON events.id == matches.event # Join the Event so we can see the Event Name INNER JOIN match_scores ON matches.id == match_scores.match # Join the Scores so we can filter based on score INNER JOIN match_teams ON matches.id == match_teams.match # Join the Teams so we can filter based on team WHERE match_teams.alliance_color == match_scores.alliance_color # Make sure the scores we're checking are the same as our team's alliance AND match_scores.total_points > 100 # Make sure the score is over 100 points AND match_teams.team == 5333 # Make sure we're checking matches with our team ORDER BY match_scores.total_points DESC # Order by the match score, descending ![]() Code:
SELECT matches.key, match_scores.total_points, match_scores.alliance_color FROM matches INNER JOIN match_scores ON matches.id == match_scores.match # Join the scores table, so we can see the scores WHERE match_scores.total_points > 250 # Filter by scores 250+ ORDER BY match_scores.total_points DESC # Order the scored descending ![]() Code:
SELECT events.short_name, matches.key, match_scores.alliance_color, match_scores.auto_boulders_high, match_scores.teleop_boulders_high FROM match_scores INNER JOIN matches ON matches.id == match_scores.match # Join the matches so we can get the match key INNER JOIN events ON matches.event == events.id # Join the events so we can get the event name WHERE match_scores.auto_boulders_high > match_scores.teleop_boulders_high # Check the auto boulders high is larger than the teleop equivilent ORDER BY match_scores.auto_boulders_high DESC # Order by auto boulders high, descending Code:
SELECT events.short_name, alliances.num, teams.id FROM alliances INNER JOIN alliance_picks ON alliances.id == alliance_picks.alliance # Join the alliance picks for this alliance INNER JOIN events ON events.id == alliances.event # Join the event for this alliance INNER JOIN teams ON alliance_picks.team == teams.id # Join the teams for the picks INNER JOIN stats ON stats.team == teams.id # Join the statistics (opr) for the teams WHERE alliance_picks.pick == 0 # Select the Captain team AND stats.event == events.id # Make sure the event we're checking OPRs is the same event we're checking alliances on AND (SELECT stats.opr FROM alliance_picks # Select the OPR stat INNER JOIN stats ON stats.team == alliance_picks.team # Join the stats to the alliance picks WHERE alliance_picks.alliance == alliances.id # Make sure the alliance we're checking is the same alliance the captain is from AND alliance_picks.pick == 1) # Make sure we're checking the 1st Pick. At this point, the OPR stat is selected > stats.opr # Check the 1st picks OPR from the previous select against the captains |
Re: Jaci's Annual FRC Datadump 2016
Thanks for pulling all this together. I use R as a tool to look at data, so it will be nice to have all this available locally to mess around with.
Very impressive! Nice work. |
SELECT events.short_name, alliances.num, teams.id, stats.opr FROM alliances INNER JOIN alliance_picks ON alliances.id == alliance_picks.alliance INNER JOIN events ON events.id == alliances.event INNER JOIN teams ON alliance_picks.team == teams.id INNER JOIN stats ON stats.team == teams.id WHERE alliance_picks.pick == 0 AND alliances.event == stats.event AND (SELECT stats.opr FROM alliance_picks INNER JOIN stats ON stats.team == alliance_picks.team WHERE alliance_picks.alliance == alliances.id AND stats.event = alliances.event AND alliance_picks.pick == 1) > stats.opr ORDER BY events.short_name, alliances.num Thanks again for putting this together. |
Jaci, how is your name pronounced? Does it rhyme with "classy" or "lacy"? |
#7
Thanks for making all this data easily accessible. So here's something my team was casually tracking throughout the season: the 100% breach club. Here's the the sql for one way to get the answer:
select substr(teams.key, 4) as team, match_counts.match_count from teams inner join (select match_teams.team, count(match_teams.id) as match_count from match_teams group by match_teams.team) as match_counts on substr(teams.key, 4) = match_counts.team inner join (select match_teams.team, sum(match_scores.defenses_breached) as breach_count from match_teams inner join match_scores on match_teams.match = match_scores.match and match_teams.alliance_color = match_scores.alliance_color group by match_teams.team) as breach_counts on substr(teams.key, 4) = breach_counts.team where match_counts.match_count = breach_counts.breach_count order by cast(substr(teams.key, 4) as int) Team Match Count 101 10 159 11 525 45 558 68 1014 30 1569 17 1750 11 1986 51 2062 28 2354 11 2767 63 2855 11 2882 10 3225 16 3238 65 3310 46 3488 10 3546 65 3683 50 3695 10 4476 12 4931 28 5254 45 5271 10 5618 27 5805 21 5905 11 5951 14 |
#9
I am not an SQL expert so I was hoping someone could help me out.
Some trivia questions I was curious in: 1. Alliance with the greatest sum of team numbers; 2. Alliance with the lowest sum of team numbers; 3. Alliance with the narrowest range of team numbers; 4. Alliance with the widest range of team numbers; 5. Any Palindrome alliances during the year? (either full team numbers like 2052,525,2502 or spread across team numbers like 610,3130,16) |
#11
6138+6137+6208 = 18483 (blue) 11+56+41 = 108 (red) |
#12
I haven't done SQL in decades. I just cobbled up an AWK script to read the match_teams table.
(ac=="red") && ($3=="red"){red+=$4; next}
(ac=="blue") && ($3=="blue"){blue+=$4; next}
(ac=="red") && ($3!="red"){
if(red>max){max=red; idmax=$1}
if(red<min){min=red; idmin=$1}
ac="blue"; blue=$4; next}
(ac=="blue") && ($3!="blue"){
if(blue>max){max=blue; idmax=$1}
if(blue<min){min=blue; idmin=$1}
ac="red"; red=$4; next}
#14
sqlite> select a.team, b.team, c.team, max(a.team+b.team+c.team) from match_teams a join match_teams b on a.match=b.match join match_teams c on b.match = c.match where a.team <> b.team and a.team <> c.team and b.team <> c.team and a.alliance_color = b.alliance_color and b.alliance_color = c.alliance_color ; 6138|6137|6208|18483 sqlite> select a.team, b.team, c.team, min(a.team+b.team+c.team) from match_teams a join match_teams b on a.match=b.match join match_teams c on b.match = c.match where a.team <> b.team and a.team <> c.team and b.team <> c.team and a.alliance_color = b.alliance_color and b.alliance_color = c.alliance_color ; 41|11|56|108 Last edited by jvriezen : 13-05-2016 at 16:43. Reason: Corrected to simply show SQL. |
#15
