Go to Post After all, when any student is isolated because of a difference - because of race, gender, social beliefs, or ideological concepts - we all lose. - MysterE [more]
Unread 25-05-2016, 13:53
hamza.mahdi hamza.mahdi is offline
hamza.mahdi is an unknown quantity at this point
Python IP camera
Hello,
I am using an axis camera and python to do visual tracking. I have a problem with the set up. There is no problem with the code interpreting. This is my first time using an IP camera so i'm not sure if I'm even doing it correctly.
Here's my code(spacing is correct on my computer)
import numpy as np
import cv2
cap = cv2.VideoCapture()
cap.open("http://169.254.197.26/")
while(cap.isOpened()):
# Capture frame-by-frame
ret, frame = cap.read()
# Our operations on the frame come here
print "hi"
# Display the resulting frame
cv2.imshow('frame',frame)
if cv2.waitKey(1) & 0xFF == ord('q'):
break
# When everything done, release the capture
cap.release()
cv2.destroyAllWindows()
Unread 25-05-2016, 15:06
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: Python IP camera
I don't think this code works. If it does then we really over complicated the way we did it.
I just made this repo public. We haven't officially cleaned it up and done our 2016 code release but it provides an example of how to read images from an IP camera in python.
https://github.com/Frc2481/paul-buny...Camera/main.py
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 25-05-2016, 15:18
Thanks for your reply,
I tried your program but it's missing a library networktables
I'm getting this error
Traceback (most recent call last):
File "C:/Users/Hamza/Pictures/chiefdelphi/main.py", line 5, in <module>
from networktables import NetworkTable
ImportError: No module named networktables
Unread 25-05-2016, 16:15
kylelanman's Avatar
Programming Mentor
AKA: Kyle
Using it verbatim might not be the best idea. You can extract the portion that actually reads the image from the camera.
Regardless the README for the repo details how to install networktables https://github.com/Frc2481/paul-bunyan
Unread 25-05-2016, 16:34
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Your URL is incorrect, you need to point at the stream page (I forget the particular URL). Additionally, your OpenCV needs to be linked to libav/ffmpeg for open-by-url to work correctly.
I wouldn't recommend doing it that way anyways, as libav/ffmpeg introduces significant latency because of the way that the stream is decoded (as of the last time I checked, which was 2 years ago).
Unread 25-05-2016, 19:51
and3212's Avatar
and3212 and3212 is offline
FRC #0401 (Copperhead Robotics)
Rookie Year: 2015
and3212 is an unknown quantity at this point
We also decided to use an AXIS IP Camera for this years game. For connecting to our IP Camera we used the following code. Just don't forget to change the IP Address that we have to the one of your camera as it is most likely different.
import cv2
import requests
import logging
import sys
from time import sleep
logging.basicConfig(level=logging.DEBUG)
if len(sys.argv) != 2:
    print("Error: specify an IP to connect to!")
    exit(0)
ip = sys.argv[1]
#Wait for IP camera to connect. Will not exit until this works
while(True):
    try:
        url = 'http://10.4.1.19/mjpg/video.mjpg' # IP Address of the Camera
        stream = requests.get(url, stream=True)
        bytes = b''
        print('Connected to IP Camera')
        break
    except:
        sleep(0.5)
        print('No cam yet')
        pass
while(True):
    # When nothing is seen there is a divide by zero error, so this skips over those frames
    try:
        # Takes frames from the camera that we can use
        bytes+=stream.raw.read(16384)
        a = bytes.find(b'\xff\xd8')
        b = bytes.find(b'\xff\xd9')
        if a!=-1 and b!=-1:
            jpg = bytes[a:b+2]
            bytes= bytes[b+2:]
            frame = cv2.imdecode(np.fromstring(jpg, dtype=np.uint8),cv2.IMREAD_COLOR)
            img = frame
        # Continue code here.....
We had trouble normally connecting to the IP Camera using just OpenCV so we decided to use the requests module. I assume you are using Python 2.7 because of your print statements but if you would like the syntax for Python 3 just message me.
