Is Magnesium ok?
Recently I was researchin exotic metal and was reminded of Magnesium'a wonderful light weight and structural properties. So my question is: based on recent years rules would magnesium be allowed on a robot in a structural role?
Re: Is Magnesium ok?
Magnesium is pretty explosive, so if you have some magnesium chips in your electronics, your robot might catch fire. I'd say it would fall under "hazardous materials", but you should ask a robot inspector
Ohh, and also don't let it get wet. Last edited by Gravity : 31-05-2016 at 12:54. Reason: Adding another precaution. |
Magnesium is not explosive it is used for wheels on high end cars all day long. The shavings or swarf created when machining do need to be handled properly they can catch fire and burn very well once they catch. The little fire starter kits that you scrap the savings off then spark up is a block of magnesium and flint for the spark.
If you have a mentor or sponsor that has a ton of it and machines it regularly great. If you just want an exotic metal on your robot to say you used it there are way more exotic materials with very wide range of properties i.e. hastelloy torlon. Willing to bet 6061 Aluminum will still work |
All of these could be grounds for either not using it or not permitting machining on it at an event - remember, safety is more important! |
Ignition requires a mixture with adequate oxygen.
I used to make thermite I doubt your drill will do it unless you rub the bit quite a bit. DO NOT play with thermite it can be very dangerous. Quote:
Watched a fire truck full of water try to control a magnesium fire..burnt down 10 trees because they added water. DO NOT mess around: magnesium fuses can be used to ignite charges under water. Last edited by techhelpbb : 31-05-2016 at 13:38. |
#7
There's a difference between "ok" and "suitable". You are building an FRC robot; you need it to be cheap, easily made, and have quick turnaround. Lightness is important, but considering the above three, magnesium doesn't seem to be the right material for the task at hand.
Of course there are exceptions (see: carbon fiber can grabbers in 2015). |
#8
If you build with the better AL's you are already using it. It's one of the components of AL alloys.
#9
Using magnesium would only pose an issue if you are using open flame in the pits(which you shouldn't as per the rules), or are producing arcs(which you shouldn't). Magnesium is not some super sensitive substance that will spontaneously light on fire, you deliberately have to try and ignite it unless it is a finely divided powder. Aluminum powder is flammable too. As long as you work with it properly and keep chips out of your electronics I see absolutely no problems.
I would bet money that you can't ignite a size-able block(greater than 0.25" minimum dimension) of magnesium with a blowtorch(not a welding torch) in under 15 seconds. Magnesium shavings or ribbon are a different matter but even ribbon still takes effort. Buy a Class-D extinguisher if you are that paranoid. |
#10
You could also use magnesium alloys that do not have such dangerous properties. You get the weight savings and in general less concerns over volatility.
I believe the .625" dia rod you get every year in the IGUS kit is a magnesium alloy. (correct me if I am wrong?) |
#11
Nope, it's a hard-anodized aluminum shaft.
#12
I see no real safety risk associated with magnesium in the operation of the robot or in the pits at an event.
That being said, you could burn your shop down if you are milling/turning/sawing it and create fine chips that accumulate and aren't cleared out of the machines. I don't think it really functionally offers any advantage either. there are very few non-power transmission areas on a FRC robot that benefit from more advanced materials than 6061. Those that do you're usually best off with 7075 or 4130/4140/4340. |
#13
Wasn't the housing on the NI cRIO magnesium? No one started any fires - although hopefully no one was machining it.
#14
My camera body is cast magnesium, due to the weight benefits provided. |
#15
I am familiar with magnesium's firiery tendencies. That said it is my understanding that magnesium only combusts when it melts. This question is purely academic. Also what is the danger if getting magnesium wet?
