Go to Post Continuous improvement turns good to great. Continuous tinkering can lead to inconsistent behavior and headaches. - IKE [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 31-05-2016, 22:41
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Python + Raspberry Pi + Kinect - Anyone Try it?
Has anyone tried using the a kinect on the raspberry pi with OpenCV for vision tracking? If so any good resources or places to start?
Unread 09-06-2016, 19:18
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Python + Raspberry Pi + Kinect - Anyone Try it?
Simple google search
https://github.com/xxorde/librekinect
from there you can just use openCV kerneling functions and do a tcp connection to the pi
Unread 09-06-2016, 20:01
I tied downloading that software but i ran into an issue when trying to include it into python. I can also access the camera without using that. I was hoping to get access to the infrared and camera for distance calculations.
Unread 09-06-2016, 20:31
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
I would recommend using libfreenect or OpenNI, both of which have Python wrappers that can be easily used with OpenCV. Personally, I would rather use one of these over the library Arhowk linked because they have a much larger user base and has been well tested.
I have personally used OpenNI on a Raspberry Pi 3 (but I didn't use Python) and it has worked well, apart from some initial issues setting it up.
Unread 09-06-2016, 20:55
You used OpenNI to use most if not all of the features of the kinect on the Pi 3?
Unread 09-06-2016, 21:00
Dartmouth 2020
AKA: lopsided98
I have used it to get the RGB and depth images from the Kinect, and I assume the skeleton tracking works, but I haven't tried it. OpenNI doesn't allow me to control the angle or the LEDs, but I didn't need those features.
Unread 09-06-2016, 21:01
How well was the depth camera? Was it easy to get the data back?
Unread 09-06-2016, 21:13
Dartmouth 2020
AKA: lopsided98
AFAIK, the quality of the depth image will be the same no matter what library is used. My use case was as part of ROS, so I didn't use the same system to retrieve the data as you would. Some quick research suggests it should be easy to get the depth data to OpenCV, as OpenNI is directly supported by the VideoCapture class.
Unread 09-06-2016, 21:44
Thanks for the help I will have to look into it when I get a chance.
Unread 19-12-2016, 15:06
CloakAndDagger CloakAndDagger is offline
FRC #0074 (CHAOS)
Rookie Year: 2015
CloakAndDagger is on a distinguished road
Just curious, what were you planning on using the kinect for?
We had a working kinect system in LabView, but then they made it illegal to control a robot with a kinect in auton, so we haven't pursued it in python
