Go to Post FIRST is the only sort of competition that I've seen where somebody can win and the opponents can be genuinely happy for them. - RiceRobotica [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 28-07-2016, 12:20
Ngang's Avatar
Ngang Ngang is offline
FRC #2265 (Fe Maidens)
Team Role: Electrical
Ngang is an unknown quantity at this point
Reading battery voltage Raspberry Pi
Hi, I'm working on a project with the Raspberry Pi 2. It's hooked up to a servo HAT and a battery pack. Is there a way to read the voltage on the battery? Maybe by reading how much goes into the Pi?
Unread 28-07-2016, 12:44
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Reading battery voltage Raspberry Pi
The Pi does not have analog inputs by default. However, by using an ADC you can read analog voltages. I've had good results with the MCP3008 in the past (although I wouldn't recommend using Adafruit's tutorial code for it - use the Pi's actual SPI libraries; they should be more reliable)
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
