pic: Its twins - prototype drives
Re: pic: Its twins - prototype drives
Are both the 4in and 6in wheels powered? If so, how are you planning to account for the differences in circumference between the two wheel sizes?
It looks like the 2 sets of wheels have different size sprockets, which I'm guessing is to account for this.
How do you plan on connecting the two sides? We had a somewhat similar design this year and we needed a lot of reinforcement to keep the chassis from flexing.
Will you be sharing CAD?
Just curious, what sort of efficiency loss do you get with using the right angle gears? Is the loss in efficiency/power worth the savings in space?
#7
Do you have a drop center on this? Just looking at the picture it appears all wheels make contact so I would say no. Doesn't seem it would turn well.
#8
I am also interested to know this
#9
I know it's prototype but how thick are those side rails, and those are 1/2" bolts? How's the frame work here? Anything to try and stiffen things up in sideways flexure?
#10
What is the weight of one pod as configured in the picture?
It hard to tell, but it appears you only have a few degrees of chain wrap powering the outside set of 4" wheels - definitely less than 90 degrees. You'll get bad wear on that sprocket. As others have stated, your 6" wheels are touching the ground. Turning on carpet will give you trouble. Keep working on the prototype and let us know how it performs. David |
#11
Between the bumpers and mechanisms installed this should stiffen up the frame. If I get a chance (it won't be soon) I will post the CAD drawings of the plates. We actually used the Andymark CAD to find the distances. Far as efficiency loss, I am not concerned, its small and our mechanisms are geared correctly with low power use so if we have loss at the match it will be over before it is a problem. We will just recharge the battery a little more. Between the front wheels, center and rear wheels their is a difference of .375 inch. The side plates are 3/16 thick. We do plan on cutting the bolts shorter or go with aluminum with C clips but we have had problems with the C clips coming off. The chain wrap is a problem, but we do not plan on using the center 4 inch wheels on future designs. We wanted to put double sprockets on that wheel but we only have 2 inches between the side plates and the chains barely clear now. One unit weighs 20 pounds.
#12
that's an awful lot for just one side. You're probably looking at a minumum 45-50lbs chassis once you add in the rest of it. Is there anywhere where you think you could cut down on weight? One area I would suggest is not using such a heavy plate. 2386 has run chassis similar in build from around 2010-2014. We found that as long as you supported it correctly (standoffs strategically placed throughout the "pontoon") 1/8th plate will do perfectly fine and hold up to the forces seen in a typical frc game.
#13
What exactly are you guys trying to get out of this drivetrain that could not be done with a standard 4 or 6 cim versa drive or even a kitbot? This is a 50lb drivetrain while people have made 25-35lb drivetrains out of 2x1 tube for years now. They are simpler, cheaper, have less custom parts, are stronger, easier to assemble and maintain, have more reliability can push harder, accelerate quicker, and weigh 20-50% less than this. the only advantage I see in this is that it gets the Cims out of the way and frees up some bellypan space. if thats your sole goal then i highly recomend checking out designs for gearboxes that put the cims over the top of the drive wheels. its a simpler and more proven concept than this and has many more upsides with none of the downsides i listed in this post. |
#14
We used 3/8" drop due to the AM pneumatic wheels, and found that was a good number for us.For an 8WD, having a bit of extra drop doesn't hurt a lot as long as your CoG is near the center. 4WD is definitely not a good idea, agreed. This drivetrain seems to save a ton of space compared to "normal" WCD setups, and doesn't take too many extra custom parts. They weigh less, but with a slight redesign this drivetrain too could be pretty light (maybe 40lbs for the whole deal). For this year, a 40-50lb drivetrain isn't usually a big problem because of the lightweight robots people ran in general, although the rest of the robot could be as overbuilt as this and cause you to hit 120lbs. Flipped CIM gearboxes don't save nearly as much space as this design. |
#15
1 Spur 1:1 to 6:1 94-98% Efficient 2 Straight Bevel 3:2 to 5:1 93-97% Efficient reference: "Comparison of Gear Efficiencies." MEADinfo.org . N.p., n.d. Web. 11 Aug. 2016. <http://www.meadinfo.org/2008/11/gear-efficiency-spur-helical-bevel-worm.html>. |
