Here's something interesting...
Definately interesting.
Since the botht the eduRobot and the full-size RC use the same OI, I'd guess that the functionality of user-mode display will still be there. The autonomous part is what really interests me though.... |
gah! the programmers will have something to do this year! yay!
![]() now, just to figure out how to make the robot 'dance' on it's own... |
Well isn't this essentially what we asked for in that big "Suggestions for the 2003 game" thread a while back? <insert link to appropriate thread here had I have been able to immidiately find the correct one>
I for one am looking forward to it. |
Just a question but do you mean you guys couldn't have programmed a completely autonomous robot until now using the ifi system???
we could have. infact, the programming aspect will be nothing different this year than last year (i'm assuming autnomy will be mandated), except now me and dan will need to add an "Autonomous Code" section, which is flipped on or off by a digital input. If I wanted, I could have done that this year, but i never had time, so i never bothered. it may pay to start trying some stuff though...
#7
Stephen |
#8
It was possible before, it just wasn't mandated. There are a lot of variables needed to be known in programming an autonomous robot. One of the more helpful variables is time. The robot contoller has no reliable method of telling time, or difference of time, except that data is sent at minimum every 25ms. Sometimes it may take longer depending on the size and complexity of the code. Basically this means that 25ms or more passes between looping the execution. Another variable is position. The need for this can vary based on the game. With the parts available from last years game, you could tell the position of the robot in relation to something else with the IR sensors. You could also tell the changing vertical angle of the robot with the gyro (up a ramp or down a ramp). You could also buy $100 parts and make some useful tools such as: a tachometer, a directional compass, acceleration detector, photoelectric distance measuring (up to 1.5m), magnetic material detection, and proximity sensing (including ultrasonic). However, the parts tended to be rather expensive enough that often times only one of these devices could be built with the materials given. Especially with the tachometer, which would require a separate microprocessor since the included stamp processor is rather imprecise. If they do mandate automation this year, more gadgetry, or at least a timer, will be needed to do it precisely. Unless they are only concerned with position in relation to other objects. Sure, the retroreflective tape is nice... but it's not very realistic. I mean, how often does a survivor under 2 tons of rubble have retroreflective tape strapped to their back??? How many rocks on Mars have retroreflective tape on them??? Last edited by Jnadke : 11-11-2002 at 14:10. |
#9
Re: Autonomy...
Just imagine the havoc of several 130 lb robots with unstable autonomouse controllers careening around a 44'x22' playing field. Yee-Hah! On a side note, I only discovered recently that the RC is active while in disable mode. It occurs that an autonomous program that just sends the robot forward when the motors are enabled could gain 1-2 seconds before a driver could react. Until last year, I don't think every second counted. One autonomous task that might be interesting that could be accomplished in a reasonable time would be to follow a line. This is one place where the retroreflective tape and optical sensors could actual work in a competition setting. Andrew Team 356 |
#10
Or not... i dunno. |
#11
). that meant the robot took maybe a second or so to react sometimes, although i've grown to like the delay, as i feel i can usually drive a little better with it. i did notice though, if i started the match with the joysticks pushed full forward, the robot would fly away at full speed as soon as the match began. very useful information to know . |
#12
Matt |
#13
It seems to me that FIRST has been moving tword an autonomous competition for a little while. Every year they have been giving us more and more sensors, even if very few people have used them. Maybe this year they are going to force us to use them.
#14
As far as I can tell from perusing the EduRobot material, the only way to turn on autonomous mode is to physically set the dip switches on the RC to team number 000. Unless it can also be commanded by the competition port, I don't see how autonomous mode can be required for part of the game.
Maybe the game will allow some teams to choose to fill an autonomous robot role. I.e. there may be some scoring opportunities which are only available to autonomous robots. |
#15
Was the retroflective tape sensors that sensor with the red sheilding on it??
| Interesting Find | UCGL_Guy | General Forum | 2 | 13-10-2003 11:58 |
| Interesting "Terms of Service" | George1902 | Chit-Chat | 7 | 17-09-2003 22:25 |
| Why legs rule and wheels don't. An interesting article relating to the segway | Adam Y. | Dean Kamen's Inventions | 1 | 30-10-2002 15:29 |
| Interesting facts from the FIRST 9 regionals | archiver | 2001 | 12 | 24-06-2002 02:35 |
| Interesting thing with the times | Joe Ross | CD Forum Support | 6 | 14-05-2002 21:51 |
