Hey, when testing our team's robot, the josyticks became inverted somehow. when pushing both joysticks forward (tankdrive), the robot is moving backward. I tried looking in the driver station program, but couldnt find anything about inverting the controls. Any suggestions? Thanks, Akash
Re: Joystick Issues
2) What joysticks are you using, and are you using the same joysticks as before? 3) Did your programmers add a reverse function to the code? 4) Was the robot rewired (perhaps the motor polarity switched)? |
Re: Joystick Issues
1. They switched from the last time it was turned on
2. Same Joysticks 3. Probably. 4. Nope, they are in the right way. Its probably the programmers that were testing something and forgot to revert it. I'll check with them, but thanks for the help and quick reply. |
Thanks, Taggerun 3036 |
Re: Joystick Issues
You should also consider the possibility that the left and right side drive trains have been swapped. This could be a result of wiring , configuration of the motor controllers (if CAN), or in code.
Re: Joystick Issues
Or even something as simple as the order the joysticks were plugged in!
