R Package for Downloading FIRST API Data
I was interested in both FRC and learning the R language, so I created an R package (firstapiR) to download data from the FIRST API server and convert it to R data frames. Perhaps others might find it interesting.
Here is the link to the github repository that contains the package. There are instructions on how to set up your R environment and download and install the package in the README section of the repository. Stacy Irwin Business Operations Mentor FRC 1318 Issaquah Robotics Society |
Re: R Package for Downloading FIRST API Data
Thanks for doing this! Easy access to data could spur a new generation of stat mavens. Maybe in 2017 we will see a new OPR.
Thanks for the positive feedback.
ngreen, let me know if you run into any glitches with the package, either here or in the issues section of the github repository. I was only able to test it on a couple different computers.
I considered both R and Python with the Pandas package for developing this package, and I initially played around with the FIRST API in both languages. I think Python is better as a general purpose scripting language and I found the documentation for Python to be much easier to understand than R's documentation. But for some random reason, early on, I made more progress in R than in Python. I'm experimenting with a Shiney app as well. I think Shiney could work well for building an application to present our scouting data to the drive crew -- I'm going to see if our scouting group is interested in pursuing that project. If we come up with any interesting R data visualization techniques we'll post them on the github webpages for the firstapiR package. |
Thanks for starting the API! With the right community for R, we can really bring the beginnings of data science to the masses. Machine Learning for alliance selection? K-Means for determining balanced alliances? We can really go a step further here than what exists today.
After R the next leap forward is Scala, but this is a great place to be today. |
I installed the package. Right now, I'm a little too busy but I'll try it later.
edit:I've used R some but am no expert. Last year I used clustering in R via Tableau to separate the wheat and chaff. I also liked making Shiny apps and tried to make a scouting app, but didn't end up using it. Most data I pulled from TBA or directly from the FIRST page. I didn't use the API, just direct import. Having some tools to do this in R will be useful. I have been working on getting better at making python programs to access the TBA API, but will give this a try. I don't yet know what will be better with the students, but thanks for adding this. Last edited by ngreen : 09-24-2016 at 12:23 PM. Reason: add more |
#7
Thanks for posting this. I had been thinking about something along R analysis of match data and a Shiny based scouting system. This is perfect.
One question, I looked at the whole API project on Teamforg and joined the project. But it was not clear if that automatically would get me an authorization token, or if there was some other way one had to go about requesting one. |
#8
According to the TeamForge page, they'll only be reviewing requests for tokens monthly now that the competition season is over, but they'll review weekly once build season starts up again. It may be a few weeks before you hear from Alex. |
#10
There's an R package that supposedly does this -- it's called optR and it's available on the CRAN repository. It has a function called choleskilm that should do the trick. Of course the raw data has to be shaped into a positive definite matrix first. The size of the matrix could be a problem. The description that I found on this method for calculating OPR focused on using this method for data from a single competition -- generally no more than a 100 x 100 matrix. But 2700 x 2700? I'll experiment with smaller data sets over the weekend and see if I can figure out what the computation time will be. |
#11
Welcome!
(2696/40)^3 = 306182 Big problem. Unless you use sparse matrix algorithms. Quote:
#12
Thanks for doing this. Question for R gurus: Attached is a table of qual match scores for 17842 alliances (8921 matches) involving 2696 teams. Each row has 8 fields: red1 red2 red3 blue1 blue2 blue3 red_score blue_score What is the recommended way to use R to efficiently compute "World OPR" for this large dataset? Last edited by Ether : 09-30-2016 at 03:41 PM. Reason: added attachment |
#13
Here's a re-statement of the question to make it accessible to R gurus who may not be familiar with OPR computation.
I want to know if R can solve for the least-squares solution to the overdetermined system of linear equations [A][x] = [b], given the attached [A] and [b] files. An equivalent question framed in the language of statistics would be: [A] is a table (in plaintext sparse format) of 17842 sets of values for 2696 independent variables, and b is a column of 17842 corresponding values for the dependent variable. Can R read the attached files and compute multiple linear regression? |
#14
My method requires 13 seconds on a Surface 4 with an i5 process and 8 Gb of memory. It actually takes more time to create the A matrix (9 seconds) than it does to solve for the OPRs once the A and B matrices are prepared (3 seconds). The remaining second is required for reading the data and preparing the B matrix. The results and source code are available at the link above. Stacy |
#15
![]() Reps to the first person who can cut that time in half. |
