Go to Post PLIERS: Used to round off bolt heads. - Andy A. [more]
Unread 11-10-2016, 17:00
GoldenGollem's Avatar
GoldenGollem GoldenGollem is offline
Java Programmer
FRC #2509 (Hutchinson Tigerbots)
Rookie Year: 2015
GoldenGollem is an unknown quantity at this point
No Robot Code
I was starting up a robot for the first time after the summer this past week, and when deploying the new code it showed there was no robot code. Everything is up to date as far as RoboRio image and firmware, DS, and eclipse plugins. When deployed it showed that the code deployed successfully and didn't show any errors.
If there is any suggestions please let me know.
GoldenGollem -Hutchinson Tigerbots 2509
2015 - Mini-MN Regional 2nd Place Finalist
2016 - Mini-MN Regional 1st Place Finalist
Unread 11-10-2016, 17:21
Re: No Robot Code
Look for user code runtime errors.
It's probably crashing immediately on startup.
Try starting the user code directly on the roboRIO from a command line and redirect the output to a file.
You can also check in /user/lvuser/FRCUserProgram.log on the roboRIO for additional errors.
Unread 11-10-2016, 18:04
Java Programmer
Rookie Year: 2015
Re: No Robot Code
How would I do that? or at least attempt to do successfully.
PS Here is the link to the current code
Unread 11-10-2016, 18:27
Re: No Robot Code
Are you familiar with using SSH and Linux commands?
http://wpilib.screenstepslive.com/s/...counts-and-ssh
Unread 11-10-2016, 21:35
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: No Robot Code
Unfortunately early crashes before WPILib is initialized result in the DS not getting the error message. I typically start an SSH session and use "tail -f /home/lvuser/FRCUserProgram.log" as a log, since that shows all the output
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 11-10-2016, 22:21
Jayd009's Avatar
Jayd009 Jayd009 is offline
AKA: Jonathan
FRC #4468 (Fernbank LINKS)
Rookie Year: 2016
Jayd009 is on a distinguished road
Re: No Robot Code
What you may also want to do is see if there are any objects in the code that aren't existent on the robot. For example, have you created a Talon in the code where there is no Talon on the robot?
2016: District Event Winner @ Columbus District Qualifier (PCH)
2016: Engineering Inspiration Award @ Peachtree District State Championship
2016: Tesla Subdivision Playoffs Appearance @ FIRST Championship
