Go to Post It is a difficult balancing act - we're engineers because we like to solve problems, and to take a step back and let someone else solve it, with what may be a poorer solution, is darn hard. - DonRotolo [more]
Unread 16-10-2016, 01:21
Bradley Boxer's Avatar
Bradley Boxer Bradley Boxer is offline
AKA: Bradley Boxer
FRC #0303 (TEST Team 303)
Rookie Year: 2015
Bradley Boxer is an unknown quantity at this point
Creating Separate WPIlib Installs on one User
My team was recently accepted as a Beta Tester for the 2017 software. The eclipse plugins of the new software are different in ways that make previous year's code uncompilable when using them. In order to maintain backwards compatibility, we decided to manage two separate Eclipse installations. However, the WPIlib plugins always install to C:/Users/USER/wpilib. Is there any way to define this during installation? If not, what method would you recommend of maintaining backwards compatibility with the WPI plugins?
TL;DR
Is there any way to change the WPILib plugin installation directory?
Thanks so much,
Bradley Boxer
Team 303
The opinions expressed in this post are mine and do not necessarily reflect those of my team.
Unread 16-10-2016, 01:37
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
This is probably better suited to be answered through the discussion boards in TeamForge. To get there, click Discussion in the top navigation bar.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 16-10-2016, 01:42
AKA: Bradley Boxer
Rookie Year: 2015
Re: Creating Separate WPIlib Installs on one User
Thanks, I will post there as well.
Unread 16-10-2016, 11:52
Volunteer, WPILib Contributor
no team (Waiting for 2021)
TL;DR
Thanks so much,
Bradley Boxer
Team 303
What differences are you seeing? The only change should be the location of the CANTalon package in Java. I'd be interested in hearing what else isn't working properly for you.
Regarding the multiple packages, I believe those locations are hardcoded into the plugins. I will take a look and see if there is anything we can do.
Team 4488 - Mentor 2013-2016
Unread 16-10-2016, 16:30
AKA: Bradley Boxer
Rookie Year: 2015
In addition to the CANTalon problem we were seeing a weird eclipse error where the code would not compile if the plugins were not installed completely when eclipse started. The problem would be fixed by either generating a new blank robot project or going through each .java file and saving it again.
Originally Posted by fsilberberg View Post
Short answer is no, there's no easy way. Longer answer is to take a look at this issue: https://github.com/wpilibsuite/EclipsePlugins/issues/15. If you change your HOME environment variable and then fix up things inside eclipse, you can do it. I'd suggest instead just keeping a backup of the ~/wpilib directory and swapping it as needed. If you also have two eclipse instances, each with a different version installed, you can just delete the ~/wpilib directory and then let them restore it.
Replacing the wpilib folder to match whichever installation we were running worked. Thanks!
Unread 16-10-2016, 13:47
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
