Go to Post We believe that the message of FIRST should be spreadable, just like butter - Karibou [more]
Unread 20-10-2016, 09:51
Xanawatt Xanawatt is offline
FRC #1024
Xanawatt is an unknown quantity at this point
Question "Robots don't quit!"
I did not start this thread because we have a current problem; however, this error has popped up several times over the course of the season and we were always able to find what was causing it. What happens, for those unfamiliar with the error is that the robot code appears to deploy correctly, but when you start up driverstation, there is either no code, or there is code. When there appears to be code, starting teleop causes the code to crash and "Robots don't quit!" is printed to the driverstation error log. The code then turns green again and the same thing happens. We have determined that the cause of this error is that two or more objects are assigned to the same port on the roboRIO. From research, I have found that there are more reasons that this could be thrown. Can someone please explain exactly what "Robots don't quit!" means? Also, is the first scenario that I described part of this too or is that a completely different error?
Unread 20-10-2016, 10:18
Re: "Robots don't quit!"
I think "Robots don't quit" is just related to when the user code gets far enough to complete initialization, but then later crashes.
The roboRIO automatically restarts crashed user code, so a persistent code error will cause the user code to keep restarting over and over again.
Unread 23-10-2016, 23:32
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
From what I understand, a better message for the error would be "Robots shouldn't quit." It means the robot has stopped running, and basically the program has concluded. "Robots don't quit" means your code has stopped, but real "robots don't quit." They should keep running.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 24-10-2016, 09:17
The "Robots Don't Quit" message might only be issued when the code has successfully completed restarting and it notices that it has been restarted.
That would make it accurate.
Or maybe "I get knocked down, but I get up again, cause nothin's going to keep me down."
Repeat as required...
Unread 25-10-2016, 01:17
Dan Waxman Dan Waxman is offline
FRC #0263 (Aftershock)
Rookie Year: 2016
Dan Waxman is an unknown quantity at this point
Most of the time this is just because your code through an exception -- there can be a number of reasons why this happened, and I can't comment on that without seeing your code, but that's usually the cause of the message.
