Advantages/Disadvantages of West Coast Drive
Hello Mentors/Teams/Students. I'm hoping to learn more about the advantages and pitfalls for a West Coast Drive type of chassis/drive train compared to the traditional drive train. Which of you have recently transitioned from traditional drive train to WCD? Please share your experience.. the good, the bad and the ugly!
What are unique design challenges? Maintenance issues? Challenges with buying WCD parts during the rush of build season? Cost? Reliability? Since we dont yet know what the 2017 game: is WCD drive better for certain playing field surfaces but perhaps not-so-good for other surfaces? Discuss some of the varoius versions of WCD. Anxious to hear your thoughts! Thanks Jim |
Re: Advantages/Disadvantages of West Coast Drive
What would be your definition of a traditional drivetrain? I thought that WCD was the traditional drivetrain...
Maybe 6-wheel drop-center KoP drive is traditional?
Making bearing blocks used to be the toughest part for us. Again VersaFrame COTS parts have fixed that. Mounting the gearboxes is the next challenge. There are COTS solutions for some of the drive train gearboxes. We have a milling machine to make custom mounting plates for any gearbox we use. Design challenges: You can quickly design your base frame shape to fit the scoring section configuration. Cut and rivet the tubes... (to borrow a phrase) Boom. Done. Maintenance: Wheels are easy to change if your tread wears out. Buying parts: We commit to WCD style before seeing the game and buy tubing, gussets, and bearing mounts before the season starts. We've pondered swerve drive but haven't yet committed the resources to develop one. Surface: I usually consider WCD a 6 or 8 wheel skid steer system. There are several variations on this theme. However, the wheels don't care which construction technique you use. Skid steer driving performance comes down to designing for scrub / traction forces, good construction, good control, and good weight distribution. David |
Pros:
I've found a good WCD to be far more rigid than other drivetrains. This gives it better, more consistent driving characteristics and allows you to run less drop.
#7
While my team has never built what I would consider a true WC drive train, we have incorporated at least one element of WCD in all but our rookie year. First of all, my understanding of the definition of WC vs traditional skid steer:
Common elements:
Distinctions:
Note that there are also drives which incorporate these features mix-and-match. The common example which comes to mind first is the (recently discontinued?) Andy Mark nano tube chassis. It has direct drive on four cantilevered axles, but these are the two corners, NOT the one usually nearest the CoG. Our second and third year drive trains also featured direct-drive wheels on cantilevered axes, but for similar reasons were clearly not WC drive trains [Edit: Our 2013 robot only had two driven wheels and two idle omnis, whereas our 2014 robot had mecanum drive; we learned a lot from these mistakes]. Advantages of WC:
Advantages of traditional skid steer:
#8
Well, let me tell you all about our experiences at 2363!
Quick Build Drive Train Concept Triple Helix West Coast Drive Trains |
#9
Here is my only question for you, has 254 ever not done a WCD?
I'd bet $100 that 254 does a WCD next year, and another $100 that that is what we settle on as well. It is quick, easy, and robust. Most of the design drawbacks for a particular game can be designed around with WCD without much effort, this year it was wheel spacing. |
#10
BEFORE the WCD was developed (2002-2004 timeframe), of course, but seeing as 254 is one of the developers of the WCD... The WCD was officially unleashed in late 2003/2004 season, the result of a collaboration between 254 and 60. There are photos in CD-Media from 2001 showing both teams running elements of what is now known as a WCD, though 254 for some reason ran their chains outside their frame from a central gearbox that year (either one of which would, under the traditional definition, disqualify the drive as being WCD), and neither had more than 4 wheels on the ground (also disqualifying as a WCD under the traditional definition, which requires 6 (or more, depending just how traditional you want to get)). So, more detailed answer: yes, but it's been quite a while and they were developing WCD when they did. And now back to your regularly-scheduled discussion of the pros and cons of the WCD. |
#11
We are a low resource team, like really low resource, yet we do WCD with success. Last edited by dirtbikerxz : 09-11-2016 at 09:33. |
#13
I'd disagree with that argument since it's not a function of raw number of resources but more a function of what type of resources and the allocation of them. For teams with tight budgets and resources using the KoP or VP DIAD may be better uses of tight resources. I don't see how 254-copy describes advantages or disadvantages for the purposes of resource allocation. |
