Go to Post Why does kick off take so long to get here but ship date comes toooooooooo fast? - Steve W [more]
Unread 06-11-2016, 16:57
Scoutdrago3 Scoutdrago3 is offline
FTC #5968
Scoutdrago3 is an unknown quantity at this point
Custom Gears to Fit with Tetrix Gears
Hello,
I'm looking for custom 20-tooth gears that would fit with tetrix gears, but can't seem to find anything. I found some information about general specs of the gears on these forums:
"TETRIX gears have a diametral pitch (DP) of 32 teeth/in, a pressure angle (PA) of 20 degrees, and a face width of 0.250 in" - Nate Laverdure.
I tried Amazon and a few smaller sites and can't find anything. I would just CAD it and try seeing how it holds up 3D printed, but I'm not too great with CADing custom parts, especially not gears with details specifications like that.
Unread 06-11-2016, 17:05
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Custom Gears to Fit with Tetrix Gears
sdp-si.com will have many different flavors of this gear (bore size/face width/material/etc).
2001-2004: Team 100
2006-Present: Team 254
Unread 06-11-2016, 17:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Aren't many RC car gears also 32 DP? Not sure on the pressure angle though. Check out Tower Hobbies.
Unread 06-11-2016, 19:12
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
In metal, for 32dp, 20 degree PA, .25" face width, SDP-SI has 18 and 24 tooth gears, but not 20. Fortunately if you're willing to go a bit wider or a bit thinner, they do appear to have 20t gears that meet the OP's requirements.
Also they have a far larger variety of gears with those specifications than Tetrix, so you can likely make your desired ratio work anyways, even if you want to stick with your exact requirements.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 07-11-2016, 04:24
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Originally Posted by Scoutdrago3 View Post
Hello,
Something to think about is the bore that you want. I'd say that the reason 20t gears aren't available from tetrix is that the typical FTC bolt pattern wouldn't be able to fit onto the gear as a 20t 32DP gear is quite small. You will need to think carefully about what bore you need, as it might be difficult to integrate with the other parts of your mechanism.
If you are going to 3D print the gear, it would most likely be better to 3D print both the 20t and the gear that it is meshing with in a wider and most likely lower DP. A wider gear with a lower DP will reduce the likelihood of the teeth breaking.
If you need help designing the gear just send me a PM or reply.
Sponsors, parents, students and mentors love helping teams succeed. Denso Throttle motors also want to help, don't break their hearts. REDBOX(gearbox for the throttle motor)
Facebook
Unread 07-11-2016, 10:09
Chris is me's Avatar
AKA: Pinecone
If you relax the constraint on the thickness of the gear, you'll find sources for most sizes of 32DP 20 degree pressure angle gears. Check SDP-SI, McMaster, etc. Finding one exactly 1/4" thick is going to be your biggest challenge.
McMaster has that gear available in brass or stainless steel in 3/16" face width, as well as steel in rod stock if you really need that extra 1/16" or more.
Unread 19-11-2016, 15:59
Forhire Forhire is offline
AKA: Randy Smith
FRC #4060 (S.W.A.G. 4060)
Rookie Year: 2015
Forhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond repute
Tetrix gears are actually 0.8 Mod (31.75 DP) 20 PA. 32 DP is close enough for most things, but be aware it could affect your center distance. 0.8 Mod is common in rc parts so that may help your search. You may be able to source 20 tooth pinion wire. With a 20 tooth it won't matter 32 DP or 0.8 Mod. Pinion wire is fast just bore and part off to length. Press it onto the shaft. You can also turn a shoulder for set screws if it needs to come apart later.
Before I bought a set of 0.8 module cutters I used 32 DP cutters and metric OD... this kept my center to center distance correct.
Unread 21-11-2016, 13:08
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
ServoCity has a number of 32DP gears in both metal and plastic.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 25-11-2016, 15:01
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
Just about to post same thing
https://www.servocity.com/0-250-1-4-...t-pinion-gears
2017 FTC 11722 (Coach)
2016 FTC 10544 (Coach) Canadian Championship Finalist, Rockwell Collins Innovate Award.
2014 FRC 5064 (Mentor)
