Average score per match and cycle times
During the beginning of the season when working on strategy and prototyping, we try to predict possible robot cycle times and average points pet match. Generally, at the end of the season, we look back on these estimated values and laugh, knowing that they were totally unrealistic.
How do other teams predict predict cycle times and average number of points scored per match? Is there a rule of thumb people like to use? Cheers, Devin |
Re: Average score per match and cycle times
One good rule of thumb is that a good robot will perform tasks (very approximately) as quickly as a human who is moving at a normal, not rushed pace. So try setting up a a field or just some scoring elements and timing different team members pretending to be a robot. Another thing that can help is comparing the cycle to previous games, and guessing how much easier or harder the tasks will be.
Also, just for the curiosity and observation of us all, would you be willing to share your predictions of recent games? |
For the community's enjoyment - 12 high goals per match average for one initial strategy, 5 second cycles and 23 high goals per match for a catapult prototype. Keep in mind our robot's performance was "modest" - I believe the best we ever ended up with was 3 or 4 high goals with our spring powered shooter. EDIT: And for RR (I was a freshman so I could be misquoting), but I think we were aiming for a few 4 tote stacks and never got past a couple 2-3 tote stacks. |
That awkward moment when i thought you meant Rebound Rumble, then was confused when you said tote stack
#7
For most games that involve cycling between a loading area and a scoring area, a "good" (1st round pick) team will successfully accomplish the task roughly 3 times per match.
#8
After watching the 2012 and 2013 games, we estimated that a fast robot can run a full court scoring cycle about 4-5 times early in the year and up to 6 to 7 times by Champs. Worked like a charm for 2014. For 2015 we guessed that teams could put up 4 stacks (which turned out to be reach) but alliances could put up 6 easily. For 2016, we looked at the earlier cycle times and guessed 6 full court, but noted that they could also poach.
It turned out that our high point scores for 2014, 2015 and 2016 using this method was dead on. (My son and I chose the break point on are over/under for Champs right at the eventual high score each year.) |
#9
Math and observations. We were counting the number of cycles and so we could see how many were happening for different levels of performance. In 2013 some teams got up to 7 and 8 cycles in Champs! So we see cycles of 20-30 seconds in most games.
#11
Imagine an average FRC robot doing the task, think through how slowly actions normally take. Take your estimate and multiply it by 3, and that is roughly how long an average robot will actually take to complete the task.
#12
https://xkcd.com/1658/ |
#13
Another good example is when you have multiple goals with differing point values (such as 2013 or 2016, but I only have the 2013 model built) Obviously hitting the 2 point goals was easier so your accuracy was increased, but we needed to figure out how much different the accuracy had to be to make up the point difference. This is another case where you're not looking exactly for a raw cycle speed but instead looking at points where the plot of scores reaches a local maximum. I've recently started using an online tool called guesstimate for building these models. It's reasonably easy. Here are links to 2013, 2014, and 2015. Mind you, these are not really complete models, they were built to tell me what I needed to know about the game based on our discussions. Other folks may have different needs. |
#14
At the start of every season, we try and calculate the score of a given robot archetype on an empty field in a match. For time values, we take a rough approximation that's partly heuristics and partly having a human being perform the task.
These scores give us a baseline to work off of when we're deciding what type of robot to build. In addition to counting how much score we contribute, we also create a short list of things that we require from our alliance partners to get our 4RP every match (assuming win). https://docs.google.com/spreadsheets...geU/edit#gid=0 |
#15
One of the metrics we used this year was asking what game will we see on Einstein and when has that style of play generally been introduced to the events.
2014 it was consistent three assist cycles. 2015 it was consistent capped & littered six stacks with the use of the cans from the step. For 2016 we predicted: Breach, capturing the tower with counts below 0 using the high goal, autonomous scoring, and at least one scaling machine. Using 2014 & 2015 as our main examples from the previous two seasons in districts we noticed these prime strategies typically weren't consistent until the later weeks of district play with a few exceptions. It helped to show that the simple concepts would work well in this game when looking at a tower count of 0 with low goals being much easier to accomplish in earlier weeks compared to a tower count of 0 using high goals. We also looked back at previous games and what the winning strategy was for our home regional in Week 1 knowing our first event in Week 2 had a similar playing field of fresh teams. When it came to assigning times we said 3-4 cycles from the secret passage was our maximum output early in the season potentially 5-6 later on. We assumed each cycle would take roughly 25-30 seconds conservatively breaking down our route to 5 second increments to cross defenses, cross open sections of field with limited visibility, line up to receive a ball, line up to score, and add in some extra buffer time for traffic or difficulty in one stage. Something you should always include is accuracy and plan on missing a few shots. When you crunch numbers during the first week of build season in games like 2012 & 2013 you should plan that at least one shot each cycle might miss potentially more when competing at your earlier events. Mid tier goals like 2012 & 2013 you can see some increased accuracy compared to going higher. Low goals in any game will still see missed attempts but has the highest accuracy which benefits early events. |
