Go to Post And the rest of the team helped them, encouraged them, and made a big deal about how awesome it was that we were competing for the Chairman's Award. - Carolyn_Grace [more]
Unread 30-11-2016, 21:06
JR0405's Avatar
JR0405 JR0405 is online now
#StaySavage
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 has a spectacular aura aboutJR0405 has a spectacular aura aboutJR0405 has a spectacular aura about
First Choice Solenoid Help
While comparing the two solenoids on First Choice I still can not figure out the difference between the two so I was wondering if I would need to purchase two of these in order to use this one and if I did I was wondering if there was any kind of estimate as to when they would be in stock.
Thanks
Unread 30-11-2016, 21:27
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: First Choice Solenoid Help
As far as I can tell, no. Each of these will work without any other external pieces on their own. The reason they are different is because of the different models between years. If you look at the pictures of the actual items, you'll see that the 2017 valve kit has plugs built directly into the valve itself while the 2016 one has that white plastic piece missing, and thus has that external connector. Also, both of these are included in the respective rookie kits for each year (hence the 2016 was last year), and it would make little sense to require a team to purchase a simple $5 part to make this part work at all.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 30-11-2016, 21:30
JR0405's Avatar
#StaySavage
AKA: Jack Ross
Team Role: Driver
Ok thanks that's what I thought
