Go to Post FIRST is not all about the competitions. FIRST is about what you learn to get to wherever you got to, whether that be first seed or last. - StephLee [more]
Unread 06-12-2016, 17:31
GoldenGollem's Avatar
GoldenGollem GoldenGollem is offline
Java Programmer
FRC #2509 (Hutchinson Tigerbots)
Rookie Year: 2015
GoldenGollem is an unknown quantity at this point
Repeated Error
Everytime I attempt to run a command based robot code I get this error. It only happens as soon as I add subsystems and is a command based.
ERROR
Unhandled exception instantiating robot
org.usfirst.frc2509.Robot2015d.v3.Robot java.lang.NullPointerException
at [org.usfirst.frc2509.Robot2015d.v3.Robot.<init>(Robot.java:46),
sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method),
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62),
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45),
java.lang.reflect.Constructor.newInstance(Constructor.java:408),
java.lang.Class.newInstance(Class.java:433),
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:204)
If anyone can help me go in the right direction to fix this error that would be great. Here is the link to the code.
GoldenGollem -Hutchinson Tigerbots 2509
2015 - Mini-MN Regional 2nd Place Finalist
2016 - Mini-MN Regional 1st Place Finalist
Unread 06-12-2016, 17:40
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Re: Repeated Error
Quick and Dirty Answer:
You refer to Robot.oi.lStick on line 46 of Robot.java. (See the top of the stack trace). At that point of code execution Robot.oi has been declared (see line 35), but not assigned a value yet. That doesn't happen until late inside the robotInit() function (function starts line 52, assigned value at 67).
If you just declare the variable, and remove the assignment at 46 (and 47) and assign the value in robotInit() after line 67, you should get past that problem.
(Sorry I didn't check for any others you might run into after this.)
