Go to Post "The devil" isn't in the details... The devil is having a loud house party with lots of other devils and demons in the details. And laughing, and laughing... - pfreivald [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 12-12-2016, 22:16
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
New Roborio, PDP, and CanTalons
Our pre-season robot finally was powered up tonight. A new Roborio (Imaged and Java JRE installed), New PDP, and New TalonSRX's. The PDP and TalonSRX are seen in the roboRIO Web-based Configuration and we updated the TalonSRX ID's to 1 and 2, The PDP is at ID 0 and all three devices are firmware updated. We used Robotbuilder to quickly create a two motor robotdrive with these TalonSRX speed controllers. Then generated the Java Code, Imported into eclips, and downloaded to the RoboRio.
Putting the Robot in test mode we get no response from the motors?
The lights on the PDP flash Green quickly = Robot is enabled
Light on the Talons Flash alternately orange = CAN bus detected, robot disabled
I'm milling though the documents. What am I missing?
Unread 12-12-2016, 22:39
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: New Roborio, PDP, and CanTalons
You have to initialize the CAN Talons through code for them to start in their non disabled state. Their getting the same signal they were getting when it was disabled since you're not sending any data to them.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 12-12-2016, 23:20
Rookie Year: 2015
I didn't look deep into the code but I bet my rookie coder picked TalonSRX (PWM) and not CAN Talon (CAN ID).
I will update you all when I get back to the school later in the week.
Unread 13-12-2016, 07:27
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you don't figure it out yourself, please post the code. As CAN is detected, software is the most likely culprit.
Unread 14-12-2016, 17:36
Rookie Year: 2015
Sure enough that's what it was. "Motor controller was configured as a TalonSRX not CAN Talon" If anything hopefully this will help other. Check this off as a great off season lesson.
