pic: FRC 2869 - 2016 Offseason bot
Re: pic: FRC 2869 - 2016 Offseason bot
What was the stress point?
From looking back at previous posts I believe they had problems with the cantilevering of the CIM+what looks to be a 2-3 stage VersaPlanetary from a plastic clamping gearbox. When going over defenses the Clamping Gearbox would fail.
![]() But seriously, we love that picture. That was a fun match. |
By far my favorite match of champs. Probably the most vivid FRC moment for me (I was watching as an inspector from the side of the field). You guys were awesome to compete against, hopefully we get a chance to compete in the future!
#7
Had you considered putting a pneumatic spring on the intake/lift arm for stability, smoothness of operation, and reduced force necessary to lift it?
#8
Assuming a pneumatic spring and a gas shock are the same thing, it was considered although it was a bit to late when it was. If I were to do a similar thing again I'd use a powerful normally open gas shock and a winch.
#9
I love how glossy the boulder is. It looks like a bowling ball that could actually destroy the castle!
#10
Yup, same thing!
#11
In this situation a linear actuator is also an option, allowing for very precise control with little backdrive. A good example of this is 1690, as their arm had very little flex and allowed for extremely high accuracy shooting. |
#12
As you've probably learned, rotational arm joints are sometimes tricky and require some care to do with the standard sprocket at the pivot point method of rotation. You could probably have attempted something with pneumatics, which simplifies control and is easier to make strong. Stack two pistons of different throw length on each other and now you have a four position actuator. |
#14
#15
