Go to Post Please Note: Elgin is still wearing his safety glasses. Practice safe Dewing. - JohnBoucher [more]
Unread 20-12-2016, 20:06
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Belts 9mm or 15mm?
So after four years of gear drives we are looking at maybe switching it up and moving to belts (assuming the game calls for standard 6 wheel drive.)
So in your experience what is the better choice 9 or 15mm belts?
Or maybe a better question are 9mm adequate for typical FRC loads?
Unlike 25 vs 35 chain the trade off isn't weight but size.
There are a few threads that mention this choice but none that really answered the question.
Thoughts?
Unread 20-12-2016, 20:10
Chris is me's Avatar
AKA: Pinecone
Re: Belts 9mm or 15mm?
15mm is what I would feel safest with in a drivetrain, particularly with the smaller pulleys typically used in west coast drives. 9mm is very marginal for most standard drivetrains using 24T or 27T pulleys, and can definitely fail. Once you go above 30T (for example, with a dead axle setup bolted to the wheels directly), you can probably get away with 9mm. It's a little extra space, but the result is a zero maintenance, highly reliable drivetrain. Go for it!
Unread 20-12-2016, 20:43
Oblarg Oblarg is offline
AKA: Eli Barnett
"Marginal" is the crucial term here. 9mm belts can be fine, or not, depending on your drive. 15mm are basically always safe, however, unless you're doing something really weird (exceptionally big wheels w/ exceptionally small pulleys). That said, there's certainly nothing wrong with using 9mm belts - you just have to be careful.
Also keep in mind that the stated belt specs from Gates are not necessarily accurate - those are calculated for lifetimes waaaaaaaay beyond what we expect in FRC, and we actually have a fair bit more headroom than they indicate.
If I were to give a rule of thumb for 9mm HTD belts based on my personal experience, for standard FRC drive parameters (traction-limited with a wheel COF around 1), I'd feel comfortable with 9mm belts up to, say, 42t pulleys with 5'' wheels (that yields a tooth-per-wheel-diameter ratio of ~8 teeth/in, meaning for a 3'' wheel you'd want no smaller than a 24t pulley, etc). Keep in mind that the pulley diameter/wheel diameter ratio is indeed the operative quantity here, since that determines the force on the belt.
"The breakfast of champions!"
Unread 20-12-2016, 20:56
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
4607 typically uses 9mm when we use belts. In 2016 we used them with no problems. However, there was no reduction; just strictly transfer of power (1:1 ratio). We purchased extra belts and even though we sheered a few drive shafts, our belts were never a problem. And we played in some pretty tough matches throughout the regular FRC season and in the offseason (looking at you 2052 and 5172).
Maybe this year if we have the room (we won't) we will try out the 15mm belts and pulleys we bought so long ago...
Good luck!
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 20-12-2016, 20:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We managed to break a 15mm belt by the end of the season, and I know we're not the only ones. I would be very skeptical of 9mm belts in a FIRST robot drivetrain.
Unread 20-12-2016, 21:01
AKA: Pinecone
I wasn't going off of the load ratings, but mostly personal experience. 9mm pulleys and belts have failed me at 18T and 24T before. 9mm / 24T can work, with active tensioning and very careful management, but this eliminates the big advantage of belts for me - lack of maintenance. Just go 15, and set it and forget it, is what I'd suggest.
I think your rule of thumb is pretty fair.
Anyone saying "X size belt is fine" without naming the pulley size they were using (and ideally the wheel size too, but I guess four inch is implicit for this) isn't giving the full story.
Unread 20-12-2016, 20:12
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
We have been using 15mm belts in our drivetrains recently, and everybody likes the belts over the chains. I'd really prefer to go to 9mm belts on whatever we build next though to save space. 987 has been using them for years and they seem to do just dandy, even with big wheels and small pulleys. Seems like if you get the belt tension correct they will survive easily on a 6wd setup with the center wheel direct driven by the transmission. Other configurations might be different.
Unread 20-12-2016, 20:23
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Not all belts are equal, FWIW. If you're looking at HTD profile (what VexPro and AndyMark sell) I would recommend 15mm for drivetrain. If you're running GT2/GT3 belts and pulleys, 9mm could be sufficient.
I believe 971 ran 9mm GT2 in 2013 and 2014, but switched to 15mm in 2015.
9mm can definitely work, but 15mm gives you a lot more headroom.
Unread 21-12-2016, 10:59
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
This.
If you aren't direct driving a 6wd center wheel with a transmission, I would not recommended using 9mm wide belts. That is the only drive configuration that would make them manageable. If there are small pulleys driving large high traction wheels, the 9mm wide belts will still give you problems in the 6wd direct drive center wheel.
Unread 21-12-2016, 11:16
AKA: Pinecone
Originally Posted by Deke View Post
This.
This is also a function of pulley diameter. I am not familiar with 987's setup, but from what I remember they use pulleys at least 30 tooth, not tiny like 24 tooth or smaller.
I (and many other teams) have had some problems with 24T pulleys, 9mm belts, direct driving 6wd from the center etc etc. It's right on the margin of can or can't work, and it depends on how careful the user is. I don't like my drives to ride the safety margin that closely.
Unread 21-12-2016, 11:23
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
We've used 9mm vexpro belts with 30 or 36 tooth pulleys for 2013-2015 (Rhino last year) with no issues. Never broken a belt.
Unread 24-12-2016, 15:47
This.
We ran 9mm wide, 5mm pitch belts in 2014, GT3 with a 3.5" diameter wheel and a 24 tooth pulley. The center wheel was direct driven, with belts to the front and back wheels. We carefully measured the tension, and worked hard to keep them properly tensioned to avoid ratcheting or over-tensioning. They all broke right after as the season ended.
We are going to go to 15 mm wide belts next year unless the game is something weird again. It's just not worth pushing the limits. If you read the spec sheets, we are well outside the rated range for the belts.
Unread 20-12-2016, 20:34
ARampantBrian's Avatar
ARampantBrian ARampantBrian is offline
AKA: Brian Wyatt
FRC #5188 (Classified Robotics)
ARampantBrian is on a distinguished road
What would 829 even be anymore?
Team 829 : The Digital Goats, Captain/Driver (2013-15)
Area 5188: Classified Robotics, Mentor/Coach (2015-????)
"The difference between a successful person and others is not a lack of strength,
not a lack of knowledge, but rather a lack in will." —Vince Lombardi
Unread 20-12-2016, 21:18
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
We ran 15mm belts from AndyMark in our KOP drive train last year. We've had no issues after 40+ official and practice matches and at least 50 hours of driver practice and demos.
I am a little curious - why are you going away from chain?
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 20-12-2016, 21:27
IndySam's Avatar
We haven't had a drive chain on a robot since 2012.
