When you're around my motors redline.
Unread 07-01-2017, 22:59
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Gear Defense
Anyone else noticed the lack of rules against knocking a gear off a lift? Actually, there isn't a rule against putting a bar over the top of a lift to prevent a pilot from pulling it up either. Is it grappling if it's an opposing pilot that's picking your robot up with a lift?
I'm not saying these are practical gear defense strategies, but I sure wouldn't leave a gear hanging on a lift waiting for a pickup without a robot around. Also ripe fodder for Q&A's, but lacking a team probably means I can't Q&A anymore.
Unread 07-01-2017, 23:42
Dwight_2's Avatar
Dwight_2 Dwight_2 is offline
Student Co-Leader
AKA: Dwight Howard
FRC #5842 (Royal Robotics)
Rookie Year: 2016
Dwight_2 is an unknown quantity at this point
Re: Gear Defense
There is a penalty i believe if your alliance blocks off all three of the pegs that the enemy alliance would be placing gears on (which isn't exactly a sound strategy but...?) and i believe that there is a penalty for bumping into an enemy robot while it is loading a gear within the respective zone.
Systems Integration supervisor, CAD team, Drive team, Programming team (2016), Student team Co-Leader, Documentation Chair (2017)
"It Doesn't Get Easier. You Just Get Better."
Unread 07-01-2017, 23:49
Re: Gear Defense
You're correct about blockading all three, or likely even just two lifts.
As I stated, after doing a search in the manual, there are NO rules about touching an opposing lift, knocking a gear off an opposing lift, or (just now confirmed) interfering with the placement of a gear.
You've misremembered the rule about not touching a robot that's touching a rope. Or not touching an opponent's rope.
Unread 07-01-2017, 23:44
Chris is me's Avatar
AKA: Pinecone
Re: Gear Defense
What incentive do you have to not have the pilot raise the lift as soon as possible? I don't really get why anyone would consider just leaving the gear on the floor long after the robot has physically cleared the space.
Ultimately this defense is physically constrained by the offensive robot being directly in front of the scoring element as it's going up, ideally.
Unread 07-01-2017, 23:51
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Gear Defense
You have a maximum of two pilots in the airship. It's possible that they are occupied with other lifts or rotors, and haven't been able to raise that lift yet. Alternatively, you have found some cycling method where it makes sense for you to raise 2 gears at once instead of one.
Unread 07-01-2017, 23:57
Re: Gear Defense
Pilot processing speed and efficiency is the constraint here. You've got 2 pilots and, potentially, 3 robots placing gears. I'm not promoting it as a dedicated strategy, but an opportunistic one VS a disorganized alliance. I can envision some pilots thinking they need to place a gear immediately after lifting it, leaving a gear hanging, or leaving a robot waiting and vulnerable for longer than necessary. Mostly, think of it as a caution to drivers and pilots that the gear exchange needs to be fast and actively secured.
Relatedly, the lift directly in front of your station is probably the safest to leave a gear on if you HAVE to, thanks to the terrible opposing visibility.
Unread 08-01-2017, 00:03
wheelerka's Avatar
wheelerka wheelerka is offline
AKA: Kate
FRC #3044 (0xBe4)
wheelerka is an unknown quantity at this point
Re: Gear Defense
It seems as though a gear based defense centered around knocking off gears as they were placed seems like it may not be worth much points wise, but is there any restrictions on funneling fuel balls in front of the lifts? There are two dividers between the three lifts, and you could potentially be able to cut off access to the driver station facing lift due to the fact that I'm not so sure it'd be easy to get the balls out of that area.
Unread 08-01-2017, 00:52
Re: Gear Defense
Might take a look at G21.
