Go to Post This isn't a golden ticket - it's a golden opportunity. It's up to you to earn it. - Jessica Boucher [more]
Unread 08-01-2017, 15:03
Southpaw's Avatar
Southpaw Southpaw is offline
AKA: Spencer Robinson
FRC #3184 (Blaze Robotics)
Southpaw is on a distinguished road
2017 Drive Train
There's obviously a lot of debate surrounding which drive trains can serve what purposes. This thread is created to centralize this discussion to provide easier access to all teams.
One of the more uncommon drive systems which still proves useful is the h-drive. This system has omnis on all corners, with a central omni to provide lateral movement. Our team has thrown around the idea of using h-drive as a less complicated mechanum system. The movement is near-identical to mechanum and debatably easier to build. This of course being in contrast to using tank drive (reliable and simple). Can we get some insight?
Unread 08-01-2017, 15:11
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Re: 2017 Drive Train
I'm not sure how a h-drive is simpler to build. With mecanums, you simply just mount wheels on each corner. The stock AM14U3 chassis even has support for it with Toughbox Micros. Meanwhile, with a h-drive you have to add a cross member and have a whole different drive wheel and gearbox in the middle. With H-drive you can have three gearboxes (you can tie the two side wheels together), but you need at least 5 motors. Mecanum has four gearboxes but four motors needed. Both offer challenges, but a mecanum drive is a lot simpler to mount to some versa chassis quickly (or c-channel as my team uses) and get started.
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
Unread 08-01-2017, 16:48
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
This year might be more of a swerve drive game than previous years. More control of the drivetrain can help place gears, and there's a wide open field for swerve to dance around defense in. It combines the advantages of omni or mecanums (and more) without giving up resistance towards defensive robots.
Too bad I'm not confident in my team's ability to do swerve properly.
Unread 08-01-2017, 20:25
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Mechanically, H-drive is harder to make because you need the center wheel, but programming-wise, assuming you're writing your code from the ground up, H-drive is a breeze compared to Mecanum.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 08-01-2017, 22:22
C_4187 C_4187 is offline
FRC #4187
C_4187 is an unknown quantity at this point
Mecanum vs. Tank?
Mecanum has an obvious mobility advantage, but how much does it really give up in traction/strength? Is it completely outclassed in strength to a tank drive system?
Unread 08-01-2017, 22:24
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
If there was ever a game to not overthink your drivetrain and just build a really simple tank drive, this would probably be it.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 08-01-2017, 22:27
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Agreed. Make it simple strong and compact
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 09-01-2017, 00:16
deltafief deltafief is offline
FRC #1540
deltafief is an unknown quantity at this point
Pretty much this if you go mecanum or h-drive you run the risk of getting pushed around a lot as you have to make lots of trips to get gears or fuel
Unread 09-01-2017, 00:29
Munchskull's Avatar
Team Role: CAD
There is a reason that no robot on Einstein has ever had mecanum drive. (2015 is excluded)
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 09-01-2017, 03:04
lgphoneeric's Avatar
lgphoneeric lgphoneeric is offline
FRC #2996 (Cougars Gone Wired)
lgphoneeric will become famous soon enough
So just so some newer teams don't read this thread and think that mecanum wheels are completely useless at holding their own in a game like this, check out this video from 2014. https://www.thebluealliance.com/match/2014arc_qm29
The bright red and yellow robot (us) were running the new vexpro mecanums (before the metal casters oh how we wish they had the metal insert like they do now) and we easily could hold our own in a pushing contest. The key with mecanums is that the center of gravity needs to be as low and as perfectly centered as possible.
So, do a lot of mecanum drives get pushed around, yes. BUT, if they are optimized, can they hold their own against the most pushy of robots, absolutely!
Just something to think about before teams blindly throw it out because they are under the assumption they can be pushed around with minimal effort.
If you have everything under control, something's about to break.
Former FRC Driver, Alumni, Mentor
Unread 09-01-2017, 03:50
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud of
Frankly, in that video I see your robot pushing around other mechanum/omni robots, and using its momentum well to get the occasional hits on the tank drive 'bots. Your driver is doing a great job, within the physical limitations of the system... those limitations are minimized by the low CG & good system engineering, but still definitely there.
Fun:
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
Work:
SunPower Systems, Product Engineering - Utility Power Plants (2015 - ? )
BSci, Mechanical Engineering, UCLA (2010-2015)
Unread 09-01-2017, 04:43
One was a swerve, one was a mecanum, and the third was a 6 wheel drive. But often times its more about how you drive the robot and how limitations are overcome such as using momentum. I wish I had video of it, but one of the matches during our first regional (which weirdly only a few matches were recorded) we ended up pushing an 8 wheel colson drive across the field from almost a stand still. Can mecanum drives push very often, not really, but should they be eliminated from decision discussion simply because there is a little defense, in my opinion I definitely do not think so because a good drive team with a slick drive train can do surprising things. So ultimately the point I guess I'm trying to get at is just because a drive train doesn't have as much physical grip as another doesn't mean it can't at times match or outperform a technically gripper drive train.
Unread 09-01-2017, 11:45
mypie4050's Avatar
mypie4050 mypie4050 is offline
AKA: Micah Young
FRC #4050 (Biohazard)
mypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nice
This is very good advice. Any robot with a mecanum or omin train will likely be very easy to push around and be highly ineffective at both shooting and gearing (my proposed term for scoring gears).
s-neff's Avatar
AKA: Sam
Originally Posted by C_4187 View Post
Mecanum vs. Tank?
In a pushing match, yes.
Fun:
Work:
Unread 08-01-2017, 22:46
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
SamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud of
Everyone should read this before building anything but a tank drive:
http://www.simbotics.org/resources/m...rain-selection
Sam Fuchs
236 TechnoTicks, Old Lyme, CT
2015 - Programming, Electrical
2016 - Lead Programmer, Co-Driver
2017 - Lead Programmer, Co-Driver
