Go to Post Congratulations to team 341, your work is nothing short of what I want to do when I grow up. - kjolana1124 [more]
Unread 09-01-2017, 22:50
Glacier's Avatar
Glacier Glacier is offline
The Bearded One.....
AKA: Levi Cagle
FRC #3959 (Morgan County Mech Tech)
Team Role: Webmaster
Rookie Year: 2015
Glacier is an unknown quantity at this point
Tele-op defense vs strictly focusing on cycle times and offense
What do you think? How much of a factor does defense have against slim cycle time teams?
Sent from my iPhone using Tapatalk
Unread 09-01-2017, 22:58
NShep98's Avatar
NShep98 NShep98 is online now
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
Re: Tele-op defense vs strictly focusing on cycle times and offense
I personally am very confused by the people who seem to underestimate defense as a strategy in this game. Especially where it seems (on CD at least) that more teams are focusing on gears than fuel, I would assume a fair deal of defense. Placing gears is an action that requires traversing the field, every single time, with no other possibility for obtaining them. You have nearly a full length of field where you are susceptible to defense. Even if some teams can break through defense to a moderate degree, if they end the match with an incomplete rotor assembly, the time spend acquiring every gear up from the previous rotor is essentially wasted.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 10-01-2017, 00:44
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Lots of potential for defense in this game, especially because the lifts aren't protected. With the middle of the field wide open, not too easy to play zone defense. Watch matches from 2013, common strategy was to bump and run. Don't go out of your way to play D, but if there's somebody there while you're cycling, hit them.
As for defense right at the lifts, could be very effective, but you need to have good vision because those lifts are all the way across the field and behind the airship. Need a wide-angle camera or you'll whiff as much as you hit.
You also need to project your match plan and how much time you have (realistically). If you think you'll have 20 seconds to spare without the potential to complete another cycle, or if you think you can get the second rotor but not the third, then you have time to play defense. If you're barely squeezing in that last scoring cycle, then you just try to score score score. That's the sort of choice where you definitely can't make an educated decision right now (you don't know how quick your cycles will be), so you plan for a robot that can handle the rough and tumble.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 10-01-2017, 08:05
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Effective situational defense is going to be really interesting at higher levels. If gearing is tougher than we think and a typical elim alliance takes most of a match getting all rotors going, then knowing when to go all out stopping the bot with the last gear is going to be important. Sending two climbing bots after a climbing bot with the last gear is completely rational. Keeping accurate count of opponent gears is going to be important, and feinting by waiting to spin up rotors might be a thing.
Which also means pilots will need to have decently secure one way communication with coaches to keep the drive team informed on the gears remaining. Brightly coloured glove fingers against a dark shirt. Counting gears would also be a good job for the third pilot, really.
Unread 10-01-2017, 08:23
Gdeaver Gdeaver is offline
FRC #1640
There will be robots that can not do gears, fuel or climb. They will specialize in bashing opponents robots. Be prepared to be bashed and hassled.
Unread 10-01-2017, 09:44
Glacier's Avatar
AKA: Levi Cagle
Rookie Year: 2015
Accordingly, the 5 count pin will play a huge role in playing defense for those unable to contribute offensively AKA pizzaboxes
