Go to Post For fun, someone ought to spread out a bunch of petri dishes or something all over a regional and see what you bring home with you. Or not. - KathieK [more]
Unread 11-01-2017, 22:15
abigailthefox's Avatar
abigailthefox abigailthefox is offline
FRC #1711 (Raptors)
Rookie Year: 2015
abigailthefox has a spectacular aura aboutabigailthefox has a spectacular aura about
Holonomic Drive WPILIBJ Support
My team has decided to go with a holonomic drivetrain this year, specifically four omni wheels mounted in the corners of the base, at 45 degree angles.
I am the lead programmer for our team, but I have not previously worked on programming a drivetrain with omni wheels (I am also one of only two veterans on the programming sub team, and the other also does not have experience with this).
I saw on another thread (from several years ago) a note about using the mecanumDrive_Cartesian method in the WPILIBJ to control a holonomic drive similar to the one we are using. However, the poster only mentioned that the wheels were at 45 degree angles, and although the OP was talking about omni wheels and I have never heard of someone mounting mecum wheels at 45 degree angles to the base, I wondered if anyone had experience with/has used this method with a holonomic omni drive like I have described.
If it doesn't work, I would also be interested in some pointers on working out the math for this myself, and where to start.
Unread 12-01-2017, 08:53
MuskieProgramme MuskieProgramme is online now
FRC #6420
MuskieProgramme is an unknown quantity at this point
Re: Holonomic Drive WPILIBJ Support
I am new to WPILIB so there may be a better way, but I have created a holonomic drive in FIRST Tech Challenge.
You have two joystick inputs (x and y)
You have four outputs (a, b, c, and d) arranged like so:
a b
c d
The formula will look something like this:
a = y + x
b = -y + x
c = y - x
d = -y - x
...assuming that positive power to each rotates the robot clockwise.
This isn't the "ideal" formula for holonomic driving - I have since moved on to something better at scaling. However, it is the simplest to understand and easiest to implement. If you want to understand the logic behind it, draw each wheel as a force vector, with a proposed direction. Cancel any opposing force and you can see how this particular formula works.
Unread 12-01-2017, 09:02
Yes, the mecanum method in WPILib will work with the omni drive you described above.
What gear ratio (from motor to wheel) are you planning to use?
What diameter omni wheels?
Unread 12-01-2017, 12:21
FRC #1711 (Raptors)
Rookie Year: 2015
I don't know yet, we're between a few options.
6" omni wheels.
Unread 12-01-2017, 13:14
6" omni wheels.
Well, whatever you choose, do yourself a big favor and choose based on doing some math.
If you need help, ask. There are lots of easy-to-use drivetrain spreadsheets available.
