Thread Tools |
Rating:
Display Modes |
Realistic high goal scoring rate
I keep seeing discussion about the high goal scoring rate required to maximize score. This is all well and good, but it's all theoretical. What do you think is a realistic rate of fire for a high goal shooter for an individual robot. An explanation of how you reach that number would be appreciated
Re: Realistic high goal scoring rate
This is also the sentiment from my team. We are going into this season under the idea that great teams will have 2 or 3 shooters at around 3 fuel/second.
how about 12 fuel per second?
My team was testing out our shooter yesterday and we were able to do at least 3 per second pretty accurately |
#7
#8
At any rate, if you're using an encoder to do closed loop control of your shooter speed, you want a specific gear ratio to maximize your rate of fire. You want a gear ratio that has the motor spinning at 1/2 its free speed when your wheel is at target speed, or something very close to this (err on the side of a bit more reduction). This puts the motor at its peak power point when its at firing speed, which will minimize the recovery time to target speed, or atleast minimize the speed drop when dumping an entire load of balls. Interestingly, this is not the gear ratio that spins the motor up from zero to target speed the fastest. That depends on the system dynamics, but the example I'm working with has that ratio at 40% more reduction, and increases recovery time by 16%. Which would give you a rate of fire of 86% the theoretical max. |
#11
![]() EDIT: Quote:
![]() Last edited by Eric Scheuing : 12-01-2017 at 13:19. |
#14
I think top teams will get to a dozen per second, absolutely. Multiple ways to accomplish this shooting task this year - if the way you have in mind can't do it, think outside the box a little.
*How long do you think until the first joke about crossing the streams? Quote:
1. If your wheel slows down by x% per ball, the fastest way to spin it back up to target speed is at at the peak mechanical power point. (Physics, that) And the peak power is at 12V and 50% free speed. 2. Peak power is the MOST power you'll ever get out of the motor. That's 337W for a single CIM. If it takes 33J to fire a ball, the most balls you can fire without slowing down is 10 balls per second. And that's going to be with the motor running at 1/2 free speed. If the motor's running any faster, it won't put enough energy back into the system and the wheel will slow until energy out = energy in. Last edited by Kevin Sevcik : 12-01-2017 at 14:16. |
