Drum shooter?
Does anyone here think it would be reasonable to shoot balls using a spinning drum, rather than a wheel, so that you could shoot 2 or 3 wide?
Our current plan is more or less inspired by 148's 2009 bot, Tornado, (though without the fancy ball storage) (https://www.youtube.com/watch?v=aCVLZFyEI1Y) and we were trying to see if we could put a shooter on it as well, to shoot for the high goal. Being able to empty the hopper faster would be very beneficial. |
Re: Drum shooter?
Nothing wrong with a drum to process balls. But they're much smaller than the 2009 balls. So there is a risk or jamming, or having a very narrow helix.
Trick is getting them to a high speed shooter. |
Re: Drum shooter?
I guess my original question wasn't clear. I was thinking about using a drum as the high speed shooter, in order to be able to shoot multiple balls at once, rather than a single wheel, which can only shoot one ball at a time.
Re: Drum shooter?
Drum could work .
Re: Drum shooter?
I'd love to see a continuous stream of balls flying out of a drum!
Consider the power consumption. The balls are pretty light, but trying to pull several up from the bottom of your hopper with enough speed to propel them 5+ feet in the air, all using the same mechanism is going to be challenging. |
Re: Drum shooter?
Re: Drum shooter?
Re: Drum shooter?
Re: Drum shooter?
Drum shooter is absolutely the way to go (unless anyone can design a high-capacity catapult, 1678?)
#10
Re: Drum shooter?
I agree, a drum, roller, wide wheel, what ever you call it that accepts and discharges multiple balls should work. There will be a trade off between accuracy and width. So, 2, maybe three wide is about the limit is my guess.
#11
Re: Drum shooter?
I for one would love to see a robot that launches the entire contents of their hopper with one shot of a catapult.
#12
Re: Drum shooter?
Drum/roller shooters work pretty okay I guess...
![]() Especially when coupled with a constantly-recycling hopper. |
#13
Re: Drum shooter?
Re: Drum shooter?
What I just said starts to fall apart if you have a completely linear indexing system for the fuel where it will not have to go from bulk storage to single file. This means we can index the feeding uniformly throughout the firing cycle. Unfortunately for us, this will reduce the number of fuel a robot can carry per unit volume which is not good for cycle efficiency. |
#15
Re: Drum shooter?
IMHO, you will be challenged to get a 2 wide stream into the opening. |
