Go to Post I am not a moderator, but I am John V-Neun. - Billfred [more]
Unread 14-01-2017, 02:34
dardeshna's Avatar
dardeshna dardeshna is offline
Build Captain
AKA: Devin Ardeshna
FRC #0008 (Paly Robotics | Team 8)
Rookie Year: 2015
dardeshna is an unknown quantity at this point
Using CIMCoders with Talon SRXs
When wiring CIMCoders to talons using breakout boards we've been getting inconsistent readings. Moving the drivetrain one direction makes the encoder values increase significantly more than moving it the same distance in the other direction (factor of 4 to 10). We don't have this issue when plugging into the RoboRio directly. A spare grayhill we had also worked fine.
We tried adding 10K ohm pull up resistors which seemed to work for a little while before we began to get inconsistent values again.
Has anyone else had this issue before and are pull up resistors the proper solution?
Unread 14-01-2017, 08:22
MrNick's Avatar
MrNick MrNick is offline
FRC #0088 (TJ^2)
MrNick is an unknown quantity at this point
Re: Using CIMCoders with Talon SRXs
I do believe a pull up resistor is needed, but I think you aren't using the correct resistance. See the graph here: http://www.robotshop.com/media/files...et_1-27-16.pdf. You need a different resistance depending on whether you are using 5v or 3.3v with the talon.
2016 Granite State District Event Winner
Unread 14-01-2017, 10:39
frodobaggins05's Avatar
frodobaggins05 frodobaggins05 is offline
AKA: Wiring Specialist
FRC #2783
Team Role: Electrical
Rookie Year: 2016
frodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these partsfrodobaggins05 is infamous around these parts
Are your readings only inconsistent while running the robot?
Unread 14-01-2017, 16:48
dardeshna's Avatar
Build Captain
AKA: Devin Ardeshna
Rookie Year: 2015
Readings are inconsistent whether the wheels are hand spun or driven by the motors. We don't think it's a gearbox engagement issue or anything similar.
Unread 15-01-2017, 10:19
tr6scott's Avatar
tr6scott tr6scott is online now
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Seeing the Cimcoder is a 5V sensor we used a 4.7K Ohm resistor to Vdd.
If I remember right it was 10k at 12v, but the srx is 5v/3.3v.
We used the CTE breakout for these.
Added- the encoder is 20 cpr, the srx is 4x decode the signal, so you should see 80 native counts per rev in the srx webpage. *going from Memory*
The sooner we get behind schedule, the more time we have to catch up.
Last edited by tr6scott : 15-01-2017 at 10:39. Reason: Wrong data initially... then added the native.
