Go to Post I WANT MY POOF BALLS! - Cyber Punk 234 [more]
Unread 15-01-2017, 14:26
YairZiv's Avatar
YairZiv YairZiv is offline
FRC #5951 (Makers Assemble)
Rookie Year: 2016
YairZiv is an unknown quantity at this point
VisionThread Listener?
Hello, this year my team and I want to try using vision assistance in our code. We have created an opencv program to find what we're looking for but we don't understand how to use it. When we tried constructing a VisionThread object, the last parameter was a listener of a type that extends VisionPipeline. Where do I find that? Or how do I create one? Thanks in advence. Yair Ziv from team MA 5951.
Unread 15-01-2017, 22:30
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: VisionThread Listener?
The listener is more or less a function that gets called every time the pipeline runs. You can write it as a lambda:
VisionThread visionThread = new VisionThread(usbCamera, myPipeline, () -> {
        // listener code here
Otherwise you just have a class that implements VisionRunner.Listener. The lambda is good because it makes synchronization easier (see this screensteps page)
WPILib
GRIP, RobotBuilder
Unread 16-01-2017, 06:03
YairZiv's Avatar
Rookie Year: 2016
This gives me an error saying: "The constructor VisionThread(CameraServer, VisionImplementation(A class I've created that extends VisionPipeline), () -> {}) is not defined.". What am I doing wrong?
Unread 16-01-2017, 07:04
YairZiv's Avatar
Rookie Year: 2016
NVM, found the problem, the problem was not in the listener, it was that CameraServer does not extend VideoSource , should have found the solution earlier. Thanks for helping though!
