Go to Post Even as a "mentor", I am still being mentored by engineers who work with the team. - Tom Bottiglieri [more]
Unread 16-01-2017, 17:02
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Intake/shooter feeder prototype
https://youtu.be/kXjiOVkhPv8
Here's a quick video for any of y'all that are struggling with how to pick up/feed the fuel to a shooter
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 16-01-2017, 17:27
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
Re: Intake/shooter feeder prototype
That works really well. Our polycord is being shipped tomorrow and I've never used it. I've been itching to get some prototyping experience in.
Is the polycord riding directly on hex shaft? Did you see any noticeable wear on it?
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 16-01-2017, 17:44
gorrilla's Avatar
AKA: adam spears
The shaft has two collars and a hex spacer that the belts are riding on. They have some wear but I don't think it's that bad, these are the hollow core belts.
They are less tight than they need to be as well
Adam Spears
Unread 16-01-2017, 17:50
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
The minimum minimum pulley diameter for McMaster solid core urethane solid cord belting (aka solid polycord) is 3/4" for 3/32" belts. For what looks like 1/4" belts, the minimum recommended diameter is 2". Did you feel that the polycord was being bent too tight or did it feel okay?
EDIT: hollow cord belting has an even larger minimum radius
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 16-01-2017, 18:10
gorrilla's Avatar
AKA: adam spears
Seems to be working fine, we might increase the radius of the pulleys in the next version
Adam Spears
