Go to Post I suppose this would be a bad time to reveal that Q and LookingForward are the same robot person hybrid thing... - EricVanWyk [more]
Unread 17-01-2017, 11:25
Fields's Avatar
Fields Fields is offline
Classic
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
Why the low Gear love
I'm seeing a lot of discussions on fuel delivery and scoring.
Some discussion on climbing
Very little on delivering gears quickly.
More worryingly, I keep seeing a misconception on the VALUE of gears.
Given that one gear is given to you, in teleop only, the wrong values are:
1st rotor = 40pts/gear
2nd rotor = 20pts/gear
3rd rotor = 10pts/gear
4th rotor = 6.7pts/gear
Many people are forgetting that the 4th rotor is actually:
6.7pts + 1/6 RP in qualifying, also remember that in the high goal 6.7pts take 20fuel
In playoffs these gears are 23.3pts each. 40+100pt bonus. That's 70 fuel in the high goal for each gear or 420 fuel just for the 4th rotor.
Time in two minutes:
worst case (one robot) = 10s/gear
best case (three robots) = 40s/gear
For all the emphasis everyone puts on fuel as the tiebreaker, not many alliances will get 4 rotors going, even in playoffs.
Wait... you built what now?
Unread 17-01-2017, 11:44
Brian Maher's Avatar
Brian Maher Brian Maher is online now
Questionable Decisionmakers
FRC #2791 (Shaker Robotics), FRC #1257 (Parallel Universe)
Brian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond repute
Re: Why the low Gear love
These are also not correct point values for gears. You are stating the average value of gears for each rotor assuming the gear set is completed. The following are the exact values for each gear:
  • First gear: 40 points
  • Second gear: 0 points
  • Third gear: 40 points
  • Fourth, fifth, and sixth gears: 0 points
  • Seventh gear: 40 points
  • Eighth through twelfth gears: 0 points
  • Thirteenth gear: (40 points + 1 RP) or 140 points
I think fuel will become a particularly attractive scoring option if an alliance can score more than seven gears but fewer than thirteen gears (or who can accomplish the feat of scoring all 13 of their gears). It doesn't make sense to sink time into a scoring objective that won't yield any points*.
*edit: assuming that the primary objective is to win the match
2016-present, Mentor, FRC 2791 - Shaker Robotics
2016: Tech Valley SF (5236, 2791, 3624) and Quality, Finger Lakes SF (5254, 2791, 2383), Battlecry@WPI Winner (195, 2791, 501), Robot Rumble Winner (2791, 195, 6463)
2016-present, Mentor, FRC 1257 - Parallel Universe
2016: Mount Olive Winner (1257, 5624, 1676), Bridgewater-Raritan Finalist (1257, 25, 3340, 555) and GP, MAR CMP Winner (225, 341, 1257), Archimedes SF (4003, 4564, 5842, 1257), IRI Invite
2012-2015, Student, FRC 1257 - Parallel Universe
2015: Mount Olive QF (1257, 1811, 1923) and Safety Award, North Brunswick Finalist (11, 193, 1257) and Team Spirit and Safety Awards
2014: Clifton Winner (1626, 869, 1257), MAR CMP QF (1257, 293, 303)
2013: TCNJ Safety Award
2012: Mount Olive QF (204, 303, 1257)
Unread 17-01-2017, 11:48
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I doubt we can do 5 or 6 or 7 gears on our own (and in qualifying, on our own is how we figure matches will go). So, the first three gears are worth 80 points in teleop.
Fuel....high goal....that's equivalent to 240 fuel, eh?
I love the gears.
Unread 17-01-2017, 11:56
Rangel's Avatar
Rangel Rangel is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
One thing I think a lot of people overlook is how much the first rotor doesn't matter unless it is done in autonomous. If everyone gets the first rotor free, that means no one really got it free. It artificially raises everyone's score by 40 points. That being said, getting all four rotors will be critical in playoffs because of the huge point swing bonus. If at least two alliances can do that though, it's going to come down to everything else.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 17-01-2017, 12:07
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you're talking about teleop, reduce those by one, to account for the reserve gear.
Originally Posted by MrForbes View Post
I love the gears.
We've known that about you for years.
Unread 17-01-2017, 13:19
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I love the gears.
Given that the reserve gear means every team gets that first 40 point free, if your alliance can't score 6 or more gears in a match, you're spending the ENTIRE MATCH to score +40 points. +60 if you auto the first gear. If you don't have a fuel mechanism and you're figuring you're on your own and can't hit 6 gears, your effective contribution is 2 gears for an entire match.
Which means a fuel bot with the the simplest gear mechanism that scores 2 gears and 9 low fuel beats you. Auto gear gives you a +20 cushion so a fuelbot has to score 2 gears and 63 high fuel to beat you, but still.
A robot with a passive gear mechanism, a successful "drive straight into the lift in front of you" auto and a fuel dumper is probably going to win a surprising amount of quals matches. Even more with a climber, which is looking rather easy.
Unless you expect to be a quite efficient gear bot, you ignore fuel at your peril.
Unread 17-01-2017, 13:24
MrForbes's Avatar
AKA: Jim
There does seem to be a lot of peril in this game.
Unread 17-01-2017, 13:42
Well we're dealing with unguarded open gearing operating right next to pilots and pressure vessels constructed out of HPDE. Peril is probably to be expected.
Unread 17-01-2017, 13:47
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
One way to attempt to overcome the point values that Kevin rightly pointed out is to design a very efficient gears-only bot. A team that can consistently cycle rapidly and get three rotors turning on their own would do alright. This would require a ton of automation and driver practice, but I don't think that the only top-level bots we see will be ball shooters. Someone, somewhere is going to break gears.
http://www.angelbotics.com
Remember why you're doing this.
Unread 17-01-2017, 14:28
Back after 4 years off
FRC #5279
If your alliance partners average even 1 gear each, then 6 gears (enough for 3 rotors) is worth 40 points in qualifications regardless of how many gears the team scores in total. It becomes more valuable in eliminations, if your partners can combine for 6 gears between them.
I think that teams that can average 6 gears a match are probably used to winning competitions. 6 gears seems feasible to me in the drivers station nearest the loading stations as you have a clean view of the loading stations and the peg. In the center and Boiler side drivers stations, you have an obstructed, or partially obstructed view of the loading station. Averaging 6 gears per match will be extremely difficult.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 17-01-2017, 15:14
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Averaging 6 gears per match would make you one of the top 5-10 robots in the world. Top robots in 2011 were hanging ~6 tubes on average in teleop. topping out at probably 8. And that was with a more open field, a protected scoring zone, and the ability to sit in the protected zone and grab tubes that were thrown cross field to you.
2001-2004: Team 100
2006-Present: Team 254
Unread 17-01-2017, 17:00
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Andrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant future
Remember though, in Logomotion most teams stopped what they were doing around the 25 second mark for the minibot races. With climbing happening right next to the gear scoring area and no race to climb to the top first, I think the absence of a break in the scoring momentum will increase that average a little.
Unread 17-01-2017, 17:02
Cory's Avatar
AKA: Cory McBride
Adding 10s isn't going to increase the average throughput by an additional gear.
2001-2004: Team 100
Unread 17-01-2017, 17:14
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
There's also the fact that teleop is 15 seconds longer in Steamworks than it was in Logomotion.
Unread 17-01-2017, 17:21
Rangel's Avatar
John Rangel
Others brought up good points but one huge factor is that making an effective gear scorer is arguably a lot easier to make than making something that scores tubes at tall various heights(and sometimes over another already placed tube). I think the shear reduction in the barrier of entry will make 6 gear averages a lot more common. Maybe I'm wrong and most regionals will be decided on gears alone but I hope that I'm not.
2014-? Mentor
